Old 12-04-2005, 06:04 AM   #1
sportriderseattle
sportriderseattle's Avatar
sportriderseattle is on a distinguished road
Default no start
It sure sounds like the factory anti theft deterant system. my 86.5 does the same annoying thing a few times a year. I have found the solution!
1. exit the car.
2. lock the doors using the inside lock, not the key.
3. close the door; however pull up on the outside door handle while you are closing it.
4. look thru the window to see if the blinky light on the dash starts blinking.
if it does, then simply unlock the door using your key and start your car.
if it does not, try all steps again, or try on the passenger door.
(remember, its takes a bit of time for the blinky light to start blinking.)
sportriderseattle is offline   Reply With Quote
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
