Old 12-20-2004, 01:01 PM   #1
extendor
extendor is on a distinguished road
Hi to everyone.
I am hoping that this problem has come up before for some of you. I have a Mk3 Supra that has a slight random missfire when you slowly pick the engine revs up from idle to about 3000. It has no pattern and cannot be traced to any particular cylinder (as far as I can tell). I get a few seconds without a miss then two very close then a gap etc.
Performance is fine and there is no overheating, water in oil etc and I know the CHG is good as I did it myself about 200Km ago.
I dont think it is the plugs as they are still good when inspected and have only done about 30,000. The air filter is clear and the throttle housing is clean. I have cleared all the vacuum pipes etc. I have visually checked all the connectors and the wires going to them for breaks etc.
This close to Christmas I am hoping for a low cost problem - hehe
Thanks and all the best wishes to you all.
extendor is offline   Reply With Quote
Old 12-21-2004, 11:35 PM   #2
extendor
Hi,
I have had the credit card out again and bought a set of tungsten plugs - just in case it was the obvious but this has not cured it. I cleared the codes and went for a test drive and get a code 21 Oxygen sensor. I dont know if this would be the problem. Have any of you out there had any experience of Oxygen sensors and the problems they cause. I dont think I have any choice but to bust the card limit and get another sensor but some advise would be very welcome.
Happy Christmas to one and all and lets hope for a few more smiles in '05 for everyone.
Old 12-22-2004, 10:05 AM   #3
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
hey
good luck with your problem supraforums should help out save bandwidth from having two exact same posts
but as i said on there....
change ur crank to 0
you should find yourself in limp mode i would think being that far out on timing
Pics of my build.
Do a diagnostic first!
random pics of random things... dannydavi Off Topic Forum 3 06-11-2007 07:13 AM
Random Overheating? MRice Non-Generation Specific Questions 10 03-24-2007 05:22 PM
random dying problem continues.... 2JZEFINI-17 MKIII Supra 3 11-08-2006 08:06 AM
