Old 09-26-2005, 01:29 PM   #1
scruffboy
scruffboy's Avatar
Question Is new head gasket a must?
I have an 89 Supra non-turbo with 125,000 miles on it. The engine runs great. I've had no problems. I see a lot of people recommend changing the hg. Why? This seems like a rather expensive endeavor if you are not having major engine trouble. Isn't the hg rather hard to get to? Whats involved? How about valve cover gaskets? Are there two seperate gaskets or is it one large one? Can this be done by a weekend warrior? Any help would be much appreciated.
Thanks,
James
Old 09-26-2005, 03:16 PM   #2
SupraMan1784
scruffboy, if you plan to drive your car hard or for a long time, the headgasket is a good investment to put some money into, the factory gaskets are pieces of s**t, trust us on that, it would be a good idea to replace it, its not that hard, but you will need to torque the bolts to the correct amount, i think its somwhere on this forum ive seen it a bunch of times but i dont remember it off the top of my head, you basically need the new gasket and a torque wrench, or any kind of wrench, and this could be easily done in a day...well half a day i say
Now: Saving for an MKIV
Broken Rides:
Old 09-26-2005, 08:17 PM   #3
monkihead
monkihead's Avatar
on a non-turbo, i dont think its as necessary. its a long and fun job(sarcasm) that everyone should enjoy with 100 degree weather.
monique- better off dead
Old 09-27-2005, 10:11 AM   #4
the reason the hg is a must is because.........
from the factory toyota neglected to torque the headbolts to the correct value
so they only torqued to 58ft lbs where they actually need 72ft lbs
depending on power output you want you can stay with the stock hg or upgrade to a metal head gasket
if you just wanna do the 12psi, exhaust, intake thing you should be fine (on a new hg)
for high boost/power applications a mhg is recommended (hks or cometic)
basically... the original torque setting is the failure on the 7m (it's a very capable motor)
7mges also blow hg's... just take a little longer hehe
Old 09-27-2005, 11:46 AM   #5
lethalwithasupra
Default related question
what appeared to be a metal head gasket ( a thick metal gasket between two thin gaskets, held together by 4 rivets ) came out of my supra. mostly it was the corrosion and overheating, but one of the thin layers was cracked between bores 5 & 6. 3 & 4 loooked like they were just about ta go thru as well. is a mhg really the end-all ?
understanding that my car is about as well taken care of as you'd expect ...
Old 09-27-2005, 12:35 PM   #6
have you put it back together yet?
can you take pics of the block and head surfaces (clean preferably)
Old 09-28-2005, 08:14 AM   #7
lethalwithasupra
me ? yea its together, and the boss might have thrown the gasket out. i was going to frame it and the one i crimped when it went together the first time and hang them both on my wall.
Old 09-28-2005, 12:11 PM   #8
i would say machining was not up to scratch for the mhg
just at a guess
Old 09-30-2005, 08:14 AM   #9
lethalwithasupra
half the gaskets on the manifolds were so old they splintered taking them off. don't know if thats a good thing but when i saw it i smiled.
65 alright as a torque setting ? 58 was recomended, so we went a little higher.
Old 09-30-2005, 12:51 PM   #10
SupraMan1784
thats a badd thing if they splintered coming off...they musta taken a beating over the years
Broken Rides:
