Old 12-09-2004, 07:07 AM   #1
MA70-1JZ
MA70-1JZ is on a distinguished road
Just wondering what sort of oil everyone is running. I was running Penrite HRP10 but I am just about to put in some Motul TurboLite...will let everyone know how it goes..Running 1JZ with stock turbos and bigger cooler with HKS cams!
MA70 widebody-1jz conversion with R154, HKS Type S intercooler, Tein HA coilovers, Apexi PowerFC, HKS step one Cams painted in AudiTT Blue
MA70-1JZ is offline   Reply With Quote
Old 12-11-2004, 09:31 AM   #2
hehe i'm a cheep ass at the mo running shell helix 20-50 lol
i prefer it a little thicker anyhow since i get the engine rather hot so the oil would naturally thin out a bit
i have run motul in the car but didn't really get to enjoy it much... blew the hg lol.. apparently awesome stuff tho
i will be switching to magnatec tho... what do ya think of that?
mmmm hks cams... like the dirty ones we have on our shelf at the workshop LOL... we were gonna buy cam gears to go with them but apparently you run into a problem with timing as the ecu tries to correct it all the time and therefore ends up in limp mode.... true or wives tale?
Old 12-15-2004, 05:49 AM   #3
Guest
Guest
Posts: n/a
i dont see why it would go into limp mode...the cam gears are fixed therefor i dont see how it would make any difference to timing..are you talking about a 1J or your 7M? With the 1JZ the crank angle sensor is actually on the crank so i doubt it would make any difference to that..even i the 7M i dont see it being a problem. Are you going to run the cams on a stock ECU or aftermarket..it could possibly be a problem with the stock ECU because of the bigger duration cams but if its aftermarket i dont see a problem..mine run fine! Motul turned out to be pretty good stuff...the highest number on the oil is how thin it goes when hot..so if you are worried about your oil thinning out you should get the lowest number possible..i would only run a thicker oil if i had a stupidly high oil consumption.
Cheers Ray
Old 12-15-2004, 10:39 AM   #4
MA70-1JZ
umm but yeah the TurboLite seems to be running very, no dramas at all to speak of..
Wrong oils everywhere Gunnar MKIII Supra 1 01-08-2008 04:08 PM
Synthetic Oils and Premium Gas zuni MKIII Supra 7 07-11-2007 10:27 PM
Difference in oil filters?? cars4me89 Shops & Part Reviews 13 04-24-2007 06:55 AM
