Old 09-10-2005, 08:04 PM   #1
Prez420
Prez420 is on a distinguished road
Default Check out my 'new' supra
I just recently found this beautiful 1987 Turbo.
garage kept since day 1.
75000kms original!!!
3" stainless cat back
K&N air filter
18" Stern Beast rims
235/40/18 Falken 451's all around
on the way:
Koyo Rad
Brembo drilled rotors and kevlar brake pads
XTD STAGE 3 RACING CLUTCH KIT
Cooleeze turbo inlet, rad and IC pipes ceramic coated and polished
BIC Performance DDP ceramic coated and polished
BIC Performance test pipe ceramic coated and polished
LS400 Air Flow Meter AFM and 550 injectors
Monza SSQV Blow Off Valve
Stainless Steel Brake Lines
Clutch Stainless Hydraulic Line
and very importantly.....
COBRA RADAR / LASER DETECTOR
Im open to any advice and/or suggestions and/or COMPLIMENTS (hint hint)for my new ride. thanx
~Prez
Name:	Supra 006_RESIZED_TO_700x525.jpg
ID:	15   Click image for larger version
ID:	16   Click image for larger version
ID:	17   Click image for larger version
ID:	18   Click image for larger version
Prez420 is offline   Reply With Quote
Old 09-10-2005, 09:53 PM   #2
Cool
very nice ,
looks like it's in great condition .
how much would something like that go for ?
i have the same year
Old 09-10-2005, 10:59 PM   #3
Prez420
I bought it for $8500 CAD. but I had to fly from vancouver Island to Edmonton to get it. then drove it back home.... what I drive! did a 12 hour trip in 10 hours.
Old 09-11-2005, 01:08 AM   #4
wow
that is one gorgeous car
now modify the engine
Old 09-11-2005, 01:18 AM   #5
Prez420
so again... Im up for suggestion on what to upgrade....
Old 09-11-2005, 01:50 AM   #6
Turbo Targa
Turbo Targa is on a distinguished road
Whoa, looks very sweet!
Turbo Targa is offline   Reply With Quote
Old 09-11-2005, 05:48 AM   #7
Poodles
weeeeeell... once you start upgrading, you'll want more boost since it's the only real way to get a LOT more power, and with that comes certain limititations. Head gaskets are weak on these cars sicne the torques spec is so low from the factory (very odd on a toyota). Once you hit more boost, you'll also hit fuel cut, so you'll need to get an FCD or do the 550cc injector/lexus AFM swap.
Great car, and if you don't mod and push more boost, the head gasket should last you for a while. If you still have the old sawblade wheels, keep em and put some sticky rubber on em and race it
Also, it seems like you have the money, so you can instead dot eh Wilwood big brake kit instead of the brembo / kevlar pads. Not cheap, but very nice looking, and Wilwood knows what they are doing, so performance is going to be even better than they look.
K&N air filters are good, but there is better. I noticed you didn't talk about upgrading suspension components... I notice it has TEMS on it, some people here love it, I don't have it, and it does limit selection of the types of shocks you can use. I myself will be upgrading (once I get the money of course) to a TEIN system with the in car adjustability which is like TEMS but better.
In the end, I could go on and on, have fun as it is, upgrade and have fun doing the work yourself
Old 09-11-2005, 02:53 PM   #8
Prez420
good call on the head gasket. how could I forget.
all the items listed are actually 'on the way'. I have bought them already. all but the DDP and test pipe. which are being bought monday
Prez420
1987 Supra Turbo
www.blackrosetattoos.com
Old 09-11-2005, 02:59 PM   #9
Prez420
I have a question.
my car (in the last day or so) has started backfiring. Im also getting a fairly loud "putt" sound from under the car. could I have blown a leak in the exhaust somewhere? it only happens when I boost.
Prez420
1987 Supra Turbo
1987 supra turbo check engine lights kidthunder650 MKIII Supra 2 03-15-2007 01:34 AM
Re: Check out my new 1989 Supra colin172 MKIII Supra 1 05-26-2006 02:50 AM
check out this fugly supra!!! nezzy_dawg MKIV Supra 5 02-23-2006 11:01 PM
