Old 09-01-2005, 11:38 AM   #1
AVI
Guest
Posts: n/a
I just had the head gasket replaced on my 1989 turbo automatic with 78000 miles. Now I'm having an annoying tapping sound from the valves. My mechanic tells me he can't do anything about it and it should not hurt anything. Is there any kind of additive I can add to the oil to make the tapping noice go away?
Old 09-01-2005, 12:16 PM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
tell your mechanic to learn how to adjust/change out shims
your clearances will be out on the shims/buckets hence the slight tapping
quite an involved task and will cost you more in labour than parts heh
Pics of my build.
Do a diagnostic first!
Old 09-03-2005, 08:17 PM   #3
acousticrawk
acousticrawk is on a distinguished road
yup, shes right. go to a toyota dealer, we use feeler guages and turn the cams and use shims to adjust the gap betweent the shim and the rocker.
acousticrawk is offline   Reply With Quote
Old 09-04-2005, 06:02 AM   #4
Poodles
Poodles is on a distinguished road
sounds like he didn't put the shims back in the right places...
Poodles is offline   Reply With Quote
Old 10-27-2005, 05:16 AM   #5
Clayson
Clayson is on a distinguished road
Post
uh yeah the shimes are the small peaces that go inbettween the valve stems and the spring correct??? why would u even need to replace them to replace a head gasket? some one wanna explane that to me?? learn somthin new for me.... i'm only 14
Clayson is offline   Reply With Quote
Old 10-29-2005, 07:22 AM   #6
mrnickleye
mrnickleye's Avatar
If he only replaced the gasket, then the cams would stay in the head, and thus the shims would not be touched. If he sent it to the machine shop to be checked for warpage and cracks, then the cams and springs were probably removed.
The shims sit on top of the valve stems, and are under each cam lobe.
They must be adjusted when ever they are taken out, and when a valve job is done. Most people never adjust them after the initial settings are done, even when they get a little noisy from wear.
Hearing a "tick/knock" sound at idol Chambers MKIII Supra 0 12-14-2007 12:37 AM
putting sound cyanide-is-a-way-out MKIII Supra 2 11-24-2007 06:40 PM
stock BOV sound question??? Curious redmaro MKIII Supra 3 09-09-2007 08:37 PM
Exhaust System SOUND?! V1P3R MKIII Supra 11 09-16-2006 08:30 AM
Exhaust sound ? redmaro MKIII Supra 4 03-24-2006 01:03 AM
