Old 12-01-2004, 05:58 AM   #1
Mk3 fo sho
Guest
Posts: n/a
my supras main bearing are really noisy, what should i do? can you fix it cheap or do i have to rebuild the entire engine? how much does it cost?
does anyone have parts?
thanks
email me
dj_carcrash@yahoo.com
Old 12-01-2004, 08:27 AM   #2
i doubt your main bearings are noisy... if they are i would be looking for another engine lol
your big end/rod bearings are mostly likely gone... how bad are they tapping... you will most likely need to get the crank ground, new bearings and also get your head and block cleaned as your bearing shavings will have gone right through it..
have you run your engine out of oil? or low? that is probably what caused it
good luck
main bearing Q please help Gengus MKIII Supra 2 05-22-2008 04:01 PM
Main pulley removal. Kuban MKIII Supra 17 03-19-2007 07:04 AM
Wheel bearings nickalvrz Non-Generation Specific Questions 1 08-25-2006 06:52 PM
Measuring Rod, Main bearing sizes Justin727 MKIII Supra 4 12-28-2005 01:43 AM
Main bearings noisy! What to do? Mk3 MKIII Supra 1 12-01-2004 08:32 AM
