Old 02-04-2010, 05:19 AM   #1
kusupra3
kusupra3 is on a distinguished road
Default Headlights won't turn off. - was: Need some help plz!!!
Hi all,
My supra headlights won't turn off even when the engine is turned off and the dash lights and other driving lights won't come on either. But fog lights work and interior lights work as well. I have checked all the fuses and everything is seems ok.
But here is the weird thing after reconnecting the battery everything works again just for that one time and after that every craps out again.
Any idea??
Thks in advance
kusupra3 is offline   Reply With Quote
Old 02-05-2010, 03:55 AM   #2
First get a young priest and an old priest!
your fog lights run their own wire. its connected to the headlights but just for power. ( I extremely simplified that)
your headlights don't turn off with the engine even if they were working correctly, you have to manually toggle them on and off. your interior lights are not connected to your headlights at all.
I would first say something about headlight relay or headlight switch. let me dig into this a tad and ill re-eddit with my findings. you mentioned that your dash lights do not come on. I would rule out switch.and go with relay. ill check into this more.
http://www.cygnusx1.net/Supra/Librar...aspx?S=BE&P=17
is the tsrm trouble shooting.
Old 02-05-2010, 04:05 AM   #3
kusupra3
Yes I manually toggled them off. When I say driving lights I mean none of my exterior lights come on, except for headlights n fog lights.
Thx alot for ur help..
Old 02-05-2010, 04:22 AM   #4
headlights up and on is what your experiencing all the time until you unplug your battery? when you toggle the switch all the way down. your headlights continue to stay on? hmm wish I knew a troubleshoot method to rule out relay and verify switch.
and none of your running lights come on at all. I would say relay! just guessing tho. but defiantly cheaper then the headlight switch
i can't determine if its a switch issue or relay. Ill dig more but hopefully someone will chime in and set us straight. in the meantime ill search for it.
here's a relay test
http://www.2carpros.com/how_to/how_d...ck_a_relay.htm
Old 02-05-2010, 04:28 AM   #5
kusupra3
That's right. Headligghts stay up all the time even when I toggle them off.
Old 02-05-2010, 04:36 AM   #6
its your headlight switch man. sorry
I just recalled that we don't have stock headlight relays.
Old 02-05-2010, 04:39 AM   #7
kusupra3
The relay is behind the hood release latch inside the dash, correct? So my dash light and driving lights are all tied with the switch?
Old 02-05-2010, 04:42 AM   #8
yep. all from your headlight switch
well your instrument lights are controlled by a reostat. (dimmer) but do they turn on less either your running lights or headlights are on? no. they get power from the same place your headlights do.
It's classic symptoms of faulty headlight switch. check your local junkyards. see if this link can yield anything
http://car-part.com/ just a junk yard database. check Pullapart.com
Oh and while replacing your switch be careful of that little spring. its a pain.
I feel down about giving you bad news. Wish I could help more buddy. good luck.
Old 02-05-2010, 04:49 AM   #9
kusupra3
ok, thx for the help. I guess I have to look for a headlight switch .
Thx again Green7mgte
Old 02-05-2010, 04:49 AM   #10
any time buddy.
Headlights not working SilenceboneSupra MKIII Supra 1 01-08-2009 10:08 PM
Headlights going bonkers! RNEMESiS42 MKIII Supra 3 12-17-2007 08:39 PM
break lights won't turn off toyosuprastl MKIII Supra 7 09-27-2007 10:43 PM
Projection Stly Headlights? critterCQB MKIII Supra 6 10-17-2006 04:27 PM
Question About Turn Signal? and a few more small Qs! V1P3R Non-Generation Specific Questions 8 08-08-2006 04:45 AM
