Old 01-18-2010, 12:56 AM   #1
wcrispino
wcrispino's Avatar
wcrispino is on a distinguished road
Unhappy 1st gear jumping out, 4th gear crunching, how do I fix it without changing gearbox
I have a 93 supra non turbo with a 5 speed manual. The problem is in 1st gear I have to hold it in because it always jumps out if I don't and also when I am driving and put it into 4th gear it crunches and sometimes jumps out too!!
How do I fix this without changing the gearbox
wcrispino is offline   Reply With Quote
Old 01-19-2010, 03:12 PM   #2
Posted in the wrong section. I'll move this to the general discussion group as the W58 was used in more than just the one model.
I don't think you are going to be able to fix this without rebuilding or replacing the gearbox.
Old 01-25-2010, 05:27 PM   #3
gteduck
gteduck is on a distinguished road
much easier to replace! probably cheaper to. if you have pieces of gears or rubbish floating around in there it could have damaged more than you think ! W58's come in two differant shifter positions, it's an easy swap if you can't get the right one ,just use the bit's off the old one.
gteduck is offline   Reply With Quote
Old 01-25-2010, 08:19 PM   #4
wcrispino
wcrispino's Avatar
Default what is 2 shifter points
What do you mean that it comes in 2 shifter points. I have never actually replaced a gear box. If I don't have the tools is it cheaper to have a workshop do it for me. How much roughly would it cost? Would it be cheaper if I source my own gearbox?
Old 01-26-2010, 04:07 PM   #5
gteduck
where the shifter enters the gearbox there is a alloy plate roughly 6 inch's long ( 150mm ) mine is located at the rear of this plate ( mark2 ) the other version , somtimes called 'short shifter' is located in the middle of the plate. I'm not sure what yours is ! 93 mark4 is it?
i got a really freash box for 675 bucks, i did look around but there not as cheap as a few years ago. i had to move the shifter back, but it was no real trouble. i just noticed you in oz, what state ? i'm in victoria, maybe i can help? all you need is 14mm open end or ring spanner (if memory serves me correctly ),rtv sealant and a little shifter or 10,12 mm spanner. sockets are best for the job if you have them? ring around and get a quote on price for box !
Old 01-27-2010, 06:14 PM   #6
gteduck
Default shifter lengths
go to ( celicasupra.com ) and do a search , type in ( W58 shift lever housing ) there are some pictures of the different lengths , 4 in total ! I didn't know there was that many .
good luck.
Old 01-28-2010, 11:24 PM   #7
wcrispino
wcrispino's Avatar
Im in sydney so I don't know how I can get the box from victoria. Do you think I can get it couriered? The box you have would it fit mine. Its a 93 so yeah i think its a mark 4. Thanks for the info.
Old 01-31-2010, 11:13 AM   #8
gteduck
I think you misunderstood me , the box i got is in my car as a friend did me the courtesy of blowing the one i had in it ,it was 20 years old thou. That's why i looked around for one . Just ring a few transmission places and ask for a box . they generally have fairly new one's they import ,not old crappy ones . check out the picture i mentioned in earlier post ,it shows the different shifter positions.
Auto to Manual transmission? dannydavi MKIII Supra 19 05-18-2007 05:33 AM
changing gear oil Levi1717 MKIII Supra 10 01-08-2007 03:34 AM
changing out ring gear Burn N' Up MKIII Supra 0 08-30-2006 07:09 PM
