Old 12-25-2009, 07:31 PM   #1
scott2298
scott2298 is on a distinguished road
Default sounds like injectors are sqeeling?
1994 supra twin (replaced by one large turbo) started a high piched sqeele sounds like it is coming from the feul rail and injectors? please help?
scott2298 is offline   Reply With Quote
Old 12-27-2009, 01:01 AM   #2
Hopefully some more folks will pitch in.... the first couple things which come to mind for me are a whistling caused by a leaking O-ring on the head side of an injector or a squeal from a failing fuel pressure regulator. I've never had to deal with this though. I'd get a stethoscope and try to pinpoint it.
Old 12-28-2009, 06:40 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Assuming this noise started after replacing a turbo, check the turbo is bolted down correctly; I had a high pitch screaming noise from my turbo (especially when cold) turn out to be the 4 bolts holding the turbo to the exhaust manifold where loose.
Correction; this was under boost condition, obviously your noise may or not be.
A Few Q's on Turbo Injectors Chambers MKIII Supra 9 11-06-2007 03:26 AM
Fuel injectors redneck ricer MKIII Supra 0 06-15-2007 02:31 AM
Car sounds like CRAP! PsychoDad MKIII Supra 2 05-30-2006 11:06 AM
what about these injectors Supraman MKIII Supra 7 01-01-2006 03:08 AM
