Old 11-23-2009, 03:26 AM   #1
jim
jim is on a distinguished road
Default boiling coolant
Help!! I have a 1992 supra turbo. Since having the HG replaced (for the second time) The engine runs hot, does not overheat, and when its turned off the cooloant in the overflow tank is boiling. the new Hg has been checked and seems to be ok. The car is frequently low on coolant. Have tried block sealer no help. Anyone have any suggestions.
jim is offline   Reply With Quote
Old 11-23-2009, 02:10 PM   #2
MA70-3.0GT
MA70-3.0GT's Avatar
Couple of quick Q's. When you had the gasket replaced did you also get the head skimmed & both it & the block tested for warpage? If the car has ever overheated really badly it may have sent the head too far out of true to be skimmed back (or possibly it's been skimmed that many times it's made the compression ratio too high).
If both the block & head were true & within spec (and I assume you fitted a standard composite HG, metal ones require further finishing work to head and block) then it could possibly be that the head was not torqued down to the correct figure, which is around 70lb as opposed to toyota's incorrect 58lb.
The first thing I would say to do though (provided block tests are coming back as no gasses in the coolant, if there are then it's a definite HG issue. If you haven't had a block test this is first on the list) is to do a search on "Burping" the heater core as this can cause BHG like symptoms due to airlocks which are hard to get rid of without following the correct procedure. From the "boiling" overflow tank though (more likely air being forced past the pressure cap making it bubble & appear to boil) I'd hazard that the HG is leaking combustion gas into the water jacket.
Hope it turns out to be the heater for your wallet's sake, best of luck & let us know how you get on.
Old 11-27-2009, 11:19 PM   #3
jim
I had the systemed 'burped" and removed the theromstat. Car drives smoothly and has stayed quite cool. No boiling in the overflow. We have noticed however a gurgiling water noise on excelleration. Other than that its running great. Is this something to be concerned about and if so any suggestions.
Old 12-09-2009, 04:13 AM   #4
The gurgling indicates air in the coolant system. Running without a thermostat is not a good idea (it's a very bad idea actually).
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
coolant on top of piston sevenmgte MKIII Supra 8 05-02-2008 02:34 AM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
