Old 11-04-2008, 02:23 AM   #3
Busted Knuckles
Busted Knuckles's Avatar
Sounds like a bad alternator. When mine went bad, battery light and brake light both came on. Radiator light means the coolant reservoir is low. double check it. Check the alternator by putting a volt meter to the battery terminals. If you don't get 13.5 to 14.5 volts, alternator is probably bad. Have it tested.
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
