Old 10-22-2008, 03:18 AM   #1
makemedie
makemedie is on a distinguished road
Default Spark Plugs (1G-GE vs 7M-GE)
I've got a 1990 MK3 Supra with the 1G-GE engine. I've been trying to find the best spark plugs I can for it on NGK or Champion's website, alongwith other manufacturers, and they all seem to only list the 7M-GE and 7M-GTE engines.
Does anyone know for certain that the 7M-GE would take the same spark plugs as the 1G-GE?
Haven't changed spark plugs in over 50,000kms, hoping to see a change in fuel consumption
makemedie is offline   Reply With Quote
Old 10-25-2008, 12:24 AM   #2
Busted Knuckles
Busted Knuckles's Avatar
Talking
Where did you find that one? I goggled it, and it is a 2.0L I6 engine used with less compression and power than the 7M-GE. Wikipedia did say some Supras used it. Wow. I doubt the 7M-GE plugs would work. The heat ranges must be different.
I located a Toyota spark plug chart, and the 1G-GE engine uses the same BPR6EY-11 plugs the 1988-1992 Corolla with the 1.3L 2E engine uses. Here's the chart.http://monroesamara.ru/files/europe.pdf
Old 10-25-2008, 02:45 AM   #3
EthanMKIII
EthanMKIII is on a distinguished road
In japan there was no N/A Supra for the 89~92 Models it was ether the 2.5L TT 1jz-gte or the 2.0L Ge-gte TT
EthanMKIII is offline   Reply With Quote
Old 10-25-2008, 06:32 AM   #4
makemedie
LOL, I know what it is, considering I have this engine in my car right now
Thanks for that link, now I just need to figure out which plugs these are in the NGK or Champion plugs range This is gonna be hard..
Old 10-25-2008, 12:32 PM   #5
Busted Knuckles
The chart IS NGKs. The order number is in the final column. That should help a great deal.
Old 10-26-2008, 05:19 AM   #6
makemedie
Holy shit! Really?! OMG you rock!
Help! LOTS of oil on top of spark plugs trevor217 MKIII Supra 5 12-17-2008 07:19 PM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
Issues After Changing Spark Plugs Getphazed MKIII Supra 8 11-03-2006 12:31 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
