Old 07-06-2005, 06:32 AM   #1
Jeff
Guest
Posts: n/a
I have an 86.5 supra. Just rebuilt the whole engine from top to bottom, and now I can't get the F**king thing started. I have the timing right and the distributor in the right place, I'm getting gas and spark to it and I have no Idea why it isn't starting.
Any Ideas?? <_<
Old 07-06-2005, 10:29 AM   #2
ddmcse
ddmcse's Avatar
i have a cam position sensor as opposed to your distributor . when i get into this situation i give the "distributor" a twist each time it doesn't start trying to find the sweet spot
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 07-06-2005, 05:47 PM   #3
Guest
Guest
Posts: n/a
Nope I figured it out. I fucked the valves on it. It has no compression and a leakege test had massive blow by through the exaust with the piston at TDC.
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
having a problem: my first supra rebuild lunar0utlaw MKIII Supra 1 07-10-2008 02:21 AM
87 supra motor rebuild kit jayde156 Non-Generation Specific Questions 1 11-02-2006 03:33 PM
1988 supra engine rebuild 1988Suprakid MKIII Supra 5 06-07-2006 09:07 PM
