Old 07-02-2005, 05:59 PM   #1
supramangte
supramangte is on a distinguished road
hey there im new here but any ways i have a 88 7mgte, when i go it she barley ran put new plugs and wires ran good, couple weeks later did a bov and air filter swap, and then started running bad again i changed the plugs and when i ran it she chirped in to 2nd :lol: this is a auto by the way,and that was the first time chirping the tires at all i turned around and went home and started running crapy, i un shimmed the bov to no shimms and put in a 180 degree thermo, and checked for vacumme leaks, found a couple leaks fixed them and now it stutters when i get into boost, and i can barley hear the bov :angry: . any help would be nice thanks
save a tree eat a beaver........
supramangte is offline   Reply With Quote
Old 07-04-2005, 08:16 PM   #2
KingDiamond
This might sound stupid, but lets start with basics, what kind of plugs did you get, and what did you set the gap to.
Old 07-04-2005, 09:02 PM   #3
supramangte
bosch paltium and they were supposed to be allready gaped, some one told me to get iraniums and someone told meto get colder plugs
Old 07-05-2005, 01:10 AM   #4
pre gapped or not they should always be checked one out of six will be off
Old 07-05-2005, 01:56 AM   #5
supramangte
ok ill double check them al thanks
Old 07-05-2005, 12:21 PM   #6
KingDiamond
Ok get rid of your bosch platinums, they suck, i didn't listen to everyone on here when they told me the same thing. I have had nothing but problems with them, and they aren't gapped properly for either application, turbo .031 or non turbo .043.
Old 07-05-2005, 12:51 PM   #7
supramangte
so what kinda plugs would you recomend i havent done much to the car just a 2 1/2 to 3inch exhaust,deleted one cat , air intake addapter and a blow off valve. and im thinking of getting a manual or eletric boost controller also. are there other easy add ons to get that supra moving a little faster?
Old 07-05-2005, 04:12 PM   #8
KingDiamond
get either nippondenso or ngk , make sure there atleast platinum, you want to go to iradium thats cool too.
Old 07-06-2005, 02:27 AM   #9
supramangte
thanks for the info ill try that
