Old 05-12-2008, 02:54 AM   #1
SuperSpartan
SuperSpartan's Avatar
SuperSpartan is on a distinguished road
Default Raising Idle
How do i raise the idle on my car
it dies only when idle or nuetral
the bar goes under 0 shouldnt it be halfway to 1?
1990 Toyota Supra Turbo!!
www.cardomain.com/ride/3067504
SuperSpartan is offline   Reply With Quote
Old 05-19-2008, 03:11 AM   #2
CyFi6
Idle should be 750-900 rpm. You can adjust it with a little screw thats on your throttle body, under a little black rubber cap. Pull the cap off and use a flatblade and unscrew the little screw a little bit. Make sure your timing is right and your ISC valve is clean also.
Old 05-19-2008, 08:44 PM   #3
SuperSpartan
Default Thanks
Will check it out a.s.a.p.
thanks for the detail considering this is my first vehicle and im clueless lol
learning as i go
well ill get back to you to see if im succesfull.
Old 05-21-2008, 12:06 PM   #4
I would definitely check your diagnostic codes first and if nothing there then check your timing to ensure it is correct before changing any screws
Old 05-24-2008, 08:05 AM   #5
SuperSpartan
Default ok
yea i did a diagnosis
and first time i got air flow sensor
YouTube - Toyota Supra Diagnosis Test
now i have alot
it seems to be O2 Sensor Air Flow and more?
please help me with this i cant decifer it all
YouTube - Toyota Supra Diagnosis Test 2
srry for bad quality and crap at end and sideways but any help would be appreciated
Old 05-24-2008, 08:36 AM   #6
Far outs... that's a few codes
k
12 = Start here MK3 TSRM On-Line
Also make sure your wiring is all good at the ignitor visibly
22 = Water temp signal, the green sensor 2 pin plug, make sure your wiring is good and not broken there
24 and 31 = Sounds like your air flow meter is fubar (f**ked up beyond all recognition) Try another one and see how it goes
Old 05-24-2008, 09:25 AM   #7
SuperSpartan
Default let go check my whip
ok time for me to go bother mom for money lol then pay her back
well yea thanks for all the help i really appreciate it! you are the best supragirl
Old 05-24-2008, 12:22 PM   #8
you could see if there's a supra owner local to you and see if they'll let ya try it first before ya spend any $$
Old 05-24-2008, 08:31 PM   #9
SuperSpartan
try the mass air flow sensor?
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
HELP!!!!!!!.....1JZ wont idle!!!!! kuroi_tuki MKIII Supra 1 07-09-2007 12:41 PM
1987 Toyota Supra Idle spycialost9999 Non-Generation Specific Questions 3 06-14-2006 06:33 PM
