Old 06-23-2005, 12:54 PM   #1
SupraDank420
SupraDank420 is on a distinguished road
I'm buying a 95 Supra this weekend or next week, luckily I found a reserved older guy who owns one and is the original owner. The car is a beaut and he only lives an hour away (just got lucky i guess). I love everything about the car, and this may sound picky, but I really wanted a Targa Top. Is it heard of to do a conversion from a regular hard top to a targa? And how much might I be looking at? Please let me know your thoughts and any of that nifty info if youve got it.
Thanx
SupraDank420 is offline   Reply With Quote
Old 06-23-2005, 07:50 PM   #2
KingDiamond
i'm hoping someone has an answer for you, i'm looking to do the same to my 87 supra.
Old 06-24-2005, 01:19 PM   #3
My86.5MintSupra
My86.5MintSupra is on a distinguished road
Thanx
About the easiest way you are going to do this is to find a wrecked car with a targa top. Take a wiz wheel and cut at the very bottom of the front and rear posts and take the entire top of the car. Run it and your car down to a body shop and tell them to put that top on your car.
I had an 88 Mustang GT T-Top car which I did just the opposite to, I put a hard top on it. After the addition of an upper and lower intake, under drive pullies, Mass air, throttle body and 373 gears....the car twisted and popped the glass T-Tops...after popping a second set...I converted the car to a hard top.
I don't work in a body shop, however I did complete phase 5 auto body in vocational during high school, and did the conversion on the mustang myself.
I can look at my 86.5 and tell the guy with the 87, peice of cake. But you would need to find a Targa top car in a scrap yard somewhere.
Getting the cuts perfect is the key, so you can just lay it on and tack it. I won't write a post describing the entire process, because I really think if you don't do body work you should just take it to a shop somewhere. I am in Northern Kentucky, and would do the conversion, weld, grind and prep for paint for around $1,500.00,(This would include me paying to have your front windshield taken out and re-installed by a glass shop) you would still need to get the top of the car sprayed. I also work a full time job and could only dedicate a couple hours a day, and weekend days on it so you'd be without your car for atleast 2 weeks.
If you aren't close to me, and you are going to take the car to a body shop, be prepared for this to be very expensive.
This is the only way to do it, you are not going to cut the car's top into a targa and make it right unless you are going to make it into a full time targa. As far as making an insert out of the peice you cut out.... no way.
My86.5MintSupra is offline   Reply With Quote
Old 06-24-2005, 05:36 PM   #4
KingDiamond
Find a supra in a junk yard? :lol: i've called so many for a simple distributor, and they all laughed at me and told me good luck. I guess the next supra i add to my collection will be a targa.
Old 06-25-2005, 04:10 AM   #5
My86.5MintSupra
You must be south or west somewhere? Down the road from me there are 9 of them in one junkyard. none of them white though, and I don't think any of those are targa's. But I did go out to Berea and look at a white one that was a Targa... fenders were worthless though.
I am desperately seeking a mint condition drivers side front fender in factory white...so Ive been all over and looked at alot of cars.
Old 06-25-2005, 06:48 AM   #6
Supra GuestAlby
Guest
Posts: n/a
I've had my car chopped about 2 years ago. the parts cost me around $900aud and the cost of getting the roof put on was $1500aud. so $2400aud all up. you can notice the car having slightly more twist in it when the roof is off but i have had no dramas with it. I recon it's well worth doing.
Old 06-25-2005, 11:49 AM   #7
KingDiamond
i'm in new jersey, and not too many supras around in my area. Usually the only time i see supras is when i pass my house.
Supra Targa Top Conversion??? XLR8307 MKIV Supra 6 08-08-2011 09:49 AM
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
Woohoo my NEW 1989 Supra Targa steelhead MKIII Supra 2 10-22-2008 07:46 PM
everyone who has a targa top..quick help please. lazy alex MKIV Supra 2 06-23-2007 12:09 AM
Conversion or no conversion?? 91 Supra MKIII Supra 1 06-17-2006 03:39 PM
