Old 03-15-2007, 05:06 AM   #1
putputcar
putputcar is on a distinguished road
Default TRAC ABS light
Hi, If you all don't mind, does anyone know if the TRAC is disable/pull fuse/remove , will that cause the abs stays on?
It's a 1997 TT auto.
thanks in advance.
putputcar is offline   Reply With Quote
Old 03-15-2007, 11:43 AM   #2
As far as I know, no it won't. Have you checked your ABS codes according to the procedures in the TSRM?
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
light issue kewlcoconut MKIII Supra 5 11-24-2005 04:28 AM
