Old 02-09-2007, 05:21 AM   #1
Chomper
Chomper is on a distinguished road
Default Low idling and to an engine halt
I have a 93 supra and having problems with it. First the engine light and warning light turns on. Drove fine for a week then starts to idle very low. Low enough to kill the engine. It also seems like the power is not there anymore. I'm wondering if its the spark plugs or the distributor. Can anyone help me out with this.
Chomper is offline   Reply With Quote
Old 02-09-2007, 01:08 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Chomper
I have a 93 supra and having problems with it. First the engine light and warning light turns on...
Use this tech article to check the code(s) that is/are triggering the engine/warning lights:
http://www.mkiv.com/techarticles/eng...bd1_codes.html
...it's as simple as jumping TE1 and E1 in the diagnostic port, turning the key on, and counting the flashes. If you post the code(s) here, we may be able to help you to resolve the condition(s) that is/are triggering the code(s).
...Drove fine for a week then starts to idle very low. Low enough to kill the engine. It also seems like the power is not there anymore. I'm wondering if its the spark plugs or the distributor...
  1. What modifications does your Supra have?
  2. When did you last change the spark plugs, and the air filter?
Life begins at 30psi.
Old 02-09-2007, 09:00 PM   #3
Chomper
Default Low idling at stop
I have a 93 non turbo supra
First, my warning and engine light came on for like a week. After that the engine starts to idle very low and to a halt at stops. I was wondering if its the spark plugs or the distributor. Also, the car seems to lack power when gasing.
Can anyone help me out?
Old 02-11-2007, 11:48 AM   #4
pwpanas
Supra Owner
pwpanas's Avatar
Please answer the questions I asked you above. Also, have you checked your ecu code(s) yet?
Old 02-13-2007, 01:30 AM   #5
Chomper
Just exaust, intake, and thats about it. Never changed the spark plugs. bought it last year.
...if you post the code(s) here, we may be able to help you to resolve the condition(s) that is/are triggering the code(s).
Old 02-13-2007, 10:45 AM   #6
pwpanas
Supra Owner
pwpanas's Avatar
Please post back when you know which code(s) is/are stored in the ecu, and we should be able to help you troubleshoot...
Idling Problem! Dejvid1785 MKIII Supra 22 10-05-2007 12:46 AM
Stayin on and Idling???? rcboricua07 MKIII Supra 6 08-21-2007 04:04 PM
"lock stop replacement"?? Japanese supra tt MKIII Supra 11 07-01-2007 02:35 AM
1986.5 Idling at high RPMS Sasukevh MKIII Supra 2 06-14-2007 04:56 AM
sumbody stop me Supra2NR Non-Generation Specific Questions 5 05-19-2006 02:29 AM
