Old 08-31-2006, 01:46 PM   #1
2JZ Beast
2JZ Beast's Avatar
2JZ Beast is on a distinguished road
Unhappy damaged engine
my engine go tdamaged during testing, so looking for a new one, any help? it was bored to 3.3 already could i go 3.5 cause two pistons got damaged, the connecting rod broke during the run. i am desperate.
1994 Supra MKIV
3.5" Ehxaust
Chromed 75mm Turbo upgrade
88mm Engine Block Bore
200 shot nitros
HKS Intercooler
Fully Polished Engine Bay
2JZ Beast is offline   Reply With Quote
Old 09-01-2006, 12:39 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Regarding your damaged engine, you could either go with a used jdm aristo 2jz-gte longblock (about $3k), or a new shortblock from 'yota (about $2400).
Regarding the bore #s you quoted, was that inches or Liters? I'd have to assume you're talking about liters, because a bore of 3.3" would be less than the oem bore size of 86mm=3.385827". If you are talking about liters, please note that an increase in bore alone can't take the 2jz-gte to 3.3L. Again, oem bore size is 86mm. 1st overbore is 86.5mm, and then max adviseable overbore 87mm. This is only a 1.2% increase, which means your new engine goes from 3L to 3.04L. I've heard that an 87.5mm or 88mm overbore is possible, but I've also heard of cracked cylinder walls, so personally I wouldn't recommend it. Even with an 88mm overbore (a 2.3% increase), you're still only looking at 3.07L. The only way to get to 3.3L or 3.4L is to install a stroker kit (but your profile doesn't mention stroker). Fwiw, I've never heard of 3.5L even with a stroker...
Lastly, I can't help but comment that you must have been either spraying a hellacious amount of no2 (a 200 shot???), or spraying under 3k rpms (or both) to break a 2jz-gte connecting rod...be sure to tell your tuner that he needs to to retard the timing based on the size of the shot (for a 200 shot, you should be retarded by at least six to eight degrees from a conservative boost-only curve), and to never spray under 3k rpms*. If you're spraying that 200 shot all at once, consider installing a progressive controller...it's harder on the solenoids, but much easier on the engine...
*Note that a very small shot (eg 50-shot), or a progressive shot can be safely sprayed at 2500-2800 rpms, if properly tuned, but the general rule for a straight shot in a 2jz-gte, with anything even in the ballpark of an oem timing curve, is no no2 under 3k.
Life begins at 30psi.
Old 09-04-2006, 02:09 PM   #3
2JZ Beast
2JZ Beast's Avatar
Thumbs up
thanks for the advise M8, it will be well taken, and sorry the block is bored to 88mm,
1994 Supra MKIV
3.5" Ehxaust
200 shot nitros
HKS Intercooler
Old 09-05-2006, 04:03 PM   #4
pwpanas
Supra Owner
pwpanas's Avatar
"...M8..." ??????
...and (fwiw) I'm still confused ... when you said "it was bored to 3.3 already could i go 3.5", were you talking inches or liters?
Old 09-05-2006, 04:18 PM   #5
Seanchp
Seanchp is on a distinguished road
He said that it was bored to a 3.3, that is .3 larger bore than stock.
Seanchp is offline   Reply With Quote
Old 09-05-2006, 04:20 PM   #6
pwpanas
Supra Owner
pwpanas's Avatar
Yes, but 3.3 what? 3.3 inches? 3.3 Liters?
.3 inches larger diameter bore? or .3 total liters larger bore? or .3 mm larger bore?
Old 09-05-2006, 04:21 PM   #7
Seanchp
Hey, where it says stock under my name, how do i change that???
Old 09-05-2006, 04:22 PM   #8
Seanchp
Im am assuming 3.3 liters instead of the original 3.0 liters
Old 09-05-2006, 04:23 PM   #9
pwpanas
Supra Owner
pwpanas's Avatar
Unfortunately, that assumption is impossible without a stroker kit. There's no physical way (even at 88mm) to get an additional .3 liters of displacement.
Old 09-05-2006, 04:24 PM   #10
2JZ Beast
2JZ Beast's Avatar
yep 3.3 liters larger than stock size of 3.0 liters. (M8 - mate)
1994 Supra MKIV
3.5" Ehxaust
200 shot nitros
HKS Intercooler
