Old 07-15-2006, 03:44 AM   #1
bigjay
bigjay is on a distinguished road
Default Buying a MKIV Supra
Im looking around for a supra. I want to know do you guy's think I should get a NA supra (cheap) and then upgading the engine or just pick up a TT ? Is there more option in the TT tant the NA ? I Know I definately want the sport roof... Any of you have problems like leakage ?
And also I would like to know what mods should be done ? In what order ?
Thanks !
Jason
bigjay is offline   Reply With Quote
Old 07-17-2006, 12:50 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
And also I would like to know what mods should be done ? In what order ?...
Starting with a TT in the first place is generally less expensive, if you want to end up with everything the TT has (including the bigger brakes, better driveline, etc.). Leakage problems with the targa are rare.
You'll find lots of info on the modifications to be done here:
http://www.mkiv.com/
...check out the "Faq" section and the "Tech Articles".
Life begins at 30psi.
Old 07-17-2006, 03:04 PM   #3
bigjay
Thanks !
Il check it out....
When moding the car how many HP is still considerd "reliable" We have all seen the potencial of the 2jz with 1000 hp. But its not only the engine we must think of... Trany, motormounts Dif,ect... What would be a good daily ?
Got Boost ?
Old 07-18-2006, 12:18 PM   #4
pwpanas
Supra Owner
pwpanas's Avatar
...When moding the car how many HP is still considerd "reliable" We have all seen the potencial of the 2jz with 1000 hp. But its not only the engine we must think of... Trany, motormounts Dif,ect... What would be a good daily ?
Think of reliability (and streetability) as a sliding scale, not as something that a car either is or isn't. In other words, if you want it to be just as reliable as stock, don't modify it. That said, imo you could proabably achieve a reasonable level of reliability for daily driving up to about 550rwhp or so. After that point, you're getting into extensive modifications (eg complete fuel system replacement, auto tranny or clutch issues, big turbos that are most efficient at a boost level that requires race fuel, etc.).
P.S. There are no problems with 1000hp and the oem 6spd, oem motormounts, or oem diff. They all easily handle that horsepower level.
Old 07-18-2006, 06:36 PM   #5
bigjay
Thanks !!
The supra realy is an amaizing machine !!
For the 550 rwhp range what turbo should be run ? single or twin ? What other mods should be done around that ?
Got Boost ?
Old 07-19-2006, 01:29 PM   #6
pwpanas
Supra Owner
pwpanas's Avatar
...For the 550 rwhp range what turbo should be run ? single or twin ? ...
Although you could run either single or twin, both with almost identical results (since all aftermarket twins run in parallel), a single will be a lot cheaper. Note that you won't get a full 550rwhp out of the oem auto tranny with good reliability - that's only with the 6spd. With the auto, don't exceed about 500rwhp.
...What other mods should be done around that ?
With the 6spd and 550rwhp, you'd need a clutch with more clamping force than oem (eg. SouthBend or RPS). With an auto and 500rwhp, no driveline modifications are required. You'll very likely need to run a few race fuel in every tank of gas (only when you're wanting to use the full 500rwhp+), or a meth injection kit, depending on your boost level & the size of the turbo you choose. Tuning is essential, so you'll need some kind of fuel controller, like an A'PEXi S-AFC2. You'll need wider rims & tires so you don't just sit there & spin with the additional power.
Lastly don't underestimate the value (and the cost) of doing regular & thorough maintenance on your Mkiv Supra Turbo, according to the owner's manual. Full synthetic oil, regular coolant flushes, tranny, brake fluid, diff, power steering, etc. fluid changes, alignments, etc. are all essential.
That's about all I'd suggest off the top of my head...other members please feel free to post additional suggestions...
a few questions about the mkIV supra :D:D bad.boy MKIV Supra 4 09-17-2008 01:27 PM
Want to learn about the Mkiv Supra? pwpanas MKIV FAQ 6 09-06-2008 05:37 PM
buying a supra docvtak MKIV Supra 6 11-16-2005 01:29 PM
