Old 04-05-2006, 11:36 PM   #3
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
I've done a bunch of searching and couldn't find any good answers. The 1990 Supra I recently bought only had 65k miles, and it ran fine for several months. The previous owner said he had retorqued the head bolts ~40k miles, and I believe him. At ~72k miles the HG started leaking slightly into cyl. 6 and a tiny bit into #2. Pulled the head off right away-no heat damage. The head bolts were right ~70 ft. lb.
So, I think I had a case of some previous HG damage from the orig. low torque, but retorquing did not prevent the BHG.
Since it appears that the Mark IV's don't usually have the problem, I just wondered what Toyota did differently. Looks like they kept the same 14 bolts but raised the torque--and maybe used a better HG.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Blown Head Gasket Snake Oil unkymurch Non-Generation Specific Questions 21 08-06-2010 02:11 AM
hks head gasket suprabahamut MKIII Supra 8 09-01-2007 04:28 AM
