Old 07-13-2015, 01:47 AM   #4
Originally Posted by Remi93supraTT View Post
Thanks for the reply well scanned my codes had a code 42 fixed that one. But then had a code 64 from my tranny wich means solenoid valve 2, ECU, or short circuit. checked both my solenoid they both worked now its my ecu the problem or my wiring.
Carefully inspect the pins in the ecu harness. A friend's Supra had a pin that had come loose, and had partially slipped back into the connector.
You should be able to use a multimeter to diagnose any other issues with the harness/wiring.
wont go past 2,000 rpms in any gear... HELP! Preston MKIII Supra 2 06-10-2011 01:52 PM
harmonic balancer came off crank shaft help? wishiknewmore MKIII Supra 3 04-15-2011 11:04 AM
turb boost increase every gear john_lauj MKIII Supra 3 09-29-2010 02:08 AM
1st gear jumping out, 4th gear crunching, how do I fix it without changing gearbox wcrispino Non-Generation Specific Questions 7 01-31-2010 11:13 AM
quick question blacksheep Non-Generation Specific Questions 10 01-01-2007 08:19 PM
