#1 |
Supra Owner
Just curious: has the sound it makes while starting changed at all since before the problem when your brother borrowed it?
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
#2 | ||
![]() Quote:
thanks for replying btw
#3 | |
Supra Owner
Given you haven't heard any new noises/sounds since your brother messed with the ignition key while running...I would suggest your next troubleshooting step should be a standard check for vacuum leaks. You can do this with a smoke machine or by pressurizing your intake system. Some folks even use a can of ether and spray near the intake system to check for leaks - for obvious reasons this isn't my top choice of troubleshooting procedure. When your mechanic said "codes are normal", what exactly did he mean? In fact, *any* code at all is abnormal...
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 04-08-2013 at 03:12 AM. |
#4 |
![]() Toyota Racing Development Join Date: Apr 2007
As fast as that starter would be spinning I would expect a fair amount of noise... but you never know how observant folks are or if they'd be able to identify the source nor do I know how much he's been driving it since this started. Just throwing the possibility out there. For me it'd be a fairly quick operation to just pull it and check for any damage, but I don't send work to a shop for such things.
I may be wrong but wouldn't an engaged starter generate voltage which could be tested for? Anyway, as I said, this scenario isn't very common as far as I know (at least not in anything since the made 80's; See: older domestics, esp. Chevy starter shim fix) and isn't likely to be the problem. I figure it is worth a quick check since kobesupra's brother insists that all he did was crank the starter while the engine was running. If this did happen I wouldn't expect the starter to function for long before the bearings start screaming and die a terrible death. If there are diagnostic codes present which the mechanic is dismissing you should have him write them down and post them. If he won't get the codes read at an auto parts store (every one around here will read codes for free). I suspect that by saying the codes are "normal" he may have meant there were none present but it's worth verifying.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Have you ever experienced someone | SupraHead | MKIII Supra | 8 | 10-30-2010 04:06 AM |
| what do you think of this setup? | Jareduhhhh | MKIV Supra | 4 | 02-19-2009 10:38 AM |
| 1988 Toyota Supra Turbo runs very rich need help | PhillyKorean | Non-Generation Specific Questions | 0 | 10-25-2008 03:28 PM |
| 1984 Toyota Supra Repair | Jake73 | Non-Generation Specific Questions | 0 | 12-09-2006 11:59 AM |
| 89 Toyota Supra N/A won't crank | pica | MKIII Supra | 3 | 05-19-2006 11:26 AM |
