Old 04-29-2012, 09:18 PM   #1
Josh122593
Josh122593 is on a distinguished road
Default AEM V2/Siemens Deka 880cc low impedance
Im having issues getting my car to idle smooth.Can anyone make a basemap for 880cc injectors and 2.35ohms.Im having trouble getting battery offset correct.Ive tried multiple injector types in the setup wizard.Maybe i just need plugs?Heres a vid.
http://www.youtube.com/watch?v=95Cj7...1&feature=plcp
Josh122593 is offline   Reply With Quote
Old 04-30-2012, 12:52 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Consider trying a lower base fuel pressure. Agreed it couldn't hurt to try new plugs.
Also note that your idle really isn't too horrible, other than the fact it is a bit rich. What happens when you reduce the pulsewidth in the idle rpm range, at low-load (i.e. idle conditions)? With 880cc injectors, unfortunately, there's no way it'll idle like stock. Note that the oem 550cc injectors spray two streams of fuel, each directed exactly at each intake valve. The oem setup as thousands and thousands of hours of engineering time to make it run the way it does. It's nearly impossible to duplicate that without an equivalent amount of work by highly trained professional tuners.
Life begins at 30psi.
Old 04-30-2012, 05:53 AM   #3
Josh122593
Ill try that.Its at 50psi and i idled it up to 1200 and its better.Ill drop the psi some.
High or Low impedance injectors? 87hilux7mge MKIII Supra 2 04-24-2011 08:32 AM
