Old 01-06-2012, 08:56 PM   #1
01max
01max is on a distinguished road
Default need help customizing my toyota supra
hi i have a 1993 toyota supra 6spd twin turbo 3.0L i want to know where can i get parts for it i need headlights front bumper, side also need low profile deep rims. i also want to know if anyone knows where is a good place to do a good paint job i live in toronto ontario. please someone help!!!!!
01max is offline   Reply With Quote
Old 01-06-2012, 11:51 PM   #2
Get new glass (euro-spec) headlights directly from Toyota - you won't regret the investment.
What rims are on it now?
Note, the tires are low-profile, not the rims. Oh, and low-profile rear tires provide almost no traction, so that's not the best course of action (depending upon your application).
Old 01-07-2012, 01:25 PM   #3
01max
Ok thanx for headlights approx how much would the headlights cost me? And i have got the orignal rims on it. Where can i take it to do a really good paint job?
Old 01-07-2012, 03:42 PM   #4
Ok thanx for headlights approx how much would the headlights cost me?...
I believe they're about $250 each... not cheap, but the improvement is REALLY worth it. No more yellowed plastic.
...And i have got the orignal rims on it....
If you're primarily concerned with performance by asking for "deep dish" rims, you could do this:
http://www.mkiv.com/techarticles/par...ned/index.html
...however, if looks is your primary goal then why did you get a TT?
I'm guessing you actually want both looks and performance, so 18s (or at most 19s) should do the trick, as long as you get them sufficiently wide with non-low-profile rubber on the rear to improve your performance too. 11.5" wide on the rear, and 9.5" wide on the front is a good balance with the oem fender widths. Again, do not get low-profile tires on the rear - they should be at least /30s (eg. 315/30R18s).
...Where can i take it to do a really good paint job?
I'd recommend you do some research. Find your local 'hot cars' hangout or a local auto show and talk to the guys with the best paint jobs. Ask them who painted their rides. Visit your local speed shops too. I promise you that the time you take to do this research will be very much worth your trouble.
Here are a couple of starting points to find your local real 'car guy' hangouts:
Dyno Power Services Ltd.
325 Unit 31, Nantucket Blvd.
Scarborough, Ontario, Canada M1P 4V5
Tel. 416-752-3966
Redline
4736 Sheppard Ave. East
Scarborough, ONT M1S 3V6
Tel: 416-292-5320
Old 01-15-2012, 02:32 AM   #5
01max
Default interior
where can i get a nice dvd player for my supra??? and what brand is good?
Old 01-18-2012, 04:25 AM   #6
This one is quite nice, and highly rated too:
http://www.pioneerelectronics.com/PU...s/AVH-P4300DVD
Old 01-18-2012, 07:57 PM   #7
01max
thanks for that i will definitely check it out. do you know any shops where i can get nice rims? like the really nice one...
Old 01-20-2012, 12:08 AM   #8
Please let me know your location. Is "scarbrough" in the UK? I believe there's also a town by that name in Ontario, Canada...
Old 01-24-2012, 12:42 AM   #9
01max
Toronto, downtown.
Old 01-28-2012, 06:54 PM   #10
Toronto, downtown.
Have you tried this place?
http://www.maximwheels.net/
Imho, you want at least 9.5" wide rims up front, and 11.5" wide rims in the rear, with the correct offsets. You can't go wider than this unless you go widebody too. Your wheel's diameter is anything 17" or bigger, based on your budget. The weight (lighter is better), and the specific 'look' of the wheel also depend on your budget. Again, the widths are key to ensuring you have sufficient launch and cornering traction as you increase your Supra's other performance characteristics (horsepower, braking, suspension, etc.).
Have you ever experienced someone SupraHead MKIII Supra 8 10-30-2010 04:06 AM
Toyota Supra Engine Question l_o_t_s_r MKIV Supra 33 08-30-2007 02:29 AM
new motor west_side_supra MKIII Supra 38 04-12-2007 10:11 PM
Anyone seen any nice Toyota Supra jackets? or any supra Aparel? supradoopa Non-Generation Specific Questions 0 01-22-2007 07:04 PM
