Old 12-04-2011, 08:12 PM   #11
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Codyjamesuno View Post
...You must know your stuff!
Sometimes I get lucky, I guess ... especially when I haven't been drinking too heavily.
Life begins at 30psi.
Old 12-06-2011, 01:57 PM   #12
Codyjamesuno
I took my stock intercooler piping off last night, I did notice the i/d is a little smaller then the set I purchased which is all aluminum, my new set is 76 mm which is 3 inch, so I am thinking the size wont be that much of a difference. Going to a project! Will keep you posted this winter! Thanks!
Old 12-07-2011, 02:22 PM   #13
Codyjamesuno
Default pictures.....
Got most of the intercooler pipe done, here are some pictures of my progress. I was able to get rid of all the stock tubing but did use one of the angle boots that came with the car that goes into the intercooler as it is a perfect fit! So basically now it's all 3 inch pipe from the intercooler to the intake! Plus, I think It looks cleaner. I do have to still order the t-clamps and work on securing everything so it doesn't move.
ID:	4392   Click image for larger version
ID:	4393   Click image for larger version
ID:	4394   Click image for larger version
Old 12-08-2011, 10:25 AM   #14
pwpanas
Supra Owner
pwpanas's Avatar
Very nice. Thank you for keeping us updated.
Just curious - Do you think you'd have had room for this modification if you still had the oem clutch fan in there?
Old 12-09-2011, 12:02 AM   #15
Codyjamesuno
no not a chance, maybe if you went with the 2.5 inch, it's a tight fit even with those electric fans, i supposed you can make anything work if you work hard enough.
cody
Intercooler setup Pic Request and Questions Semper_Fi MKIII Supra 8 07-29-2011 08:44 PM
Intercooler pipe kits? hohum MKIII Supra 2 07-26-2006 05:26 PM
