Old 11-30-2011, 02:10 PM   #1
Codyjamesuno
Default Intercooler Pipe,
I am going to redo my intercooler piping, I have an HKS side mount but I am pretty sure it mounts where the stock one did? Questions is, can I replace the factory piping with better aluminum pipe & not have to tune the car? I am new to the Supra TT thing, I got a turbo hayabusa and I know every time I change something the damn thing has to be tuned. I am guessing the less bends the better?
Thanks!
Old 12-01-2011, 01:04 PM   #2
[SupraLEGEND]
[SupraLEGEND] is on a distinguished road
Thanks!
Is it an HKS side mount IC specifically for Supra? If so, it should go right in place of the stock one. I doubt you'll have to tune it up just by replacing piping...if anything, you should feel a slight performance increase due to the smoother flowing aluminium boost piping without having to tune the car anymore...
[SupraLEGEND] is offline   Reply With Quote
Old 12-01-2011, 02:20 PM   #3
Codyjamesuno
i think so, goes in the fender on the passenger side, thanks for the help!
Thanks !
Old 12-01-2011, 03:45 PM   #4
[SupraLEGEND]
Thanks !
My pleasure man
Old 12-02-2011, 09:23 AM   #5
Turboron_99
Turboron_99's Avatar
Turboron_99 is on a distinguished road
like stated as above, Wont have to get it tuned, Yet, I would if i were you find piping that has as close to possible as the same routing and inside diameter as you have now. IF you change size and length your going to changing factors. May not need a Tune. Yet your tune wont be the same as it is now.
Turboron_99 is offline   Reply With Quote
Old 12-02-2011, 11:40 AM   #6
Thanks!
I've never heard of an HKS side-mount intercooler designed specifically for the Mkiv Supra Turbo. At one time, GReddy made an all-aluminum side mount kit, and it came with all of the piping.
Regardless, if you replace the oem rubber-like and plastic intercooler piping with (preferrably) aluminum piping that follows the same path, you won't need to re-tune at all. I'd recommend against steel piping because it's too heavy, and you don't need steel pipe to hold <40psi of air pressure. Be sure to use silicone couplings and t-bolt clamps.
Old 12-02-2011, 12:22 PM   #7
Turboron_99
Wink
Dont forget Steel will be alot more Prown to Heat Soak than nice Aluminum! Plus putting a rolled in Beed on Steel would be a PITA! Would probably have to weld a beed to the pipe!
Old 12-03-2011, 03:39 AM   #8
Actually aluminum transfers more heat from the engine bay into the charge-air system. Get the pipes ceramic coated to reduce this issue.
There is a machine that easily presses a bead into steel pipe. Many of the shops that have mandrel bending equipment also have the bead making machine.
Old 12-03-2011, 04:47 AM   #9
Codyjamesuno
I am replacing it with aluminum piping, as for the HKS side mount, I will have to look again but i'm pretty sure thats what the paper work says. I will check on that! I know the current setup I have is rubber & plastic, I think. Thanks for the help!
Old 12-03-2011, 04:49 AM   #10
Codyjamesuno
opps, you were right, it is a GReddy intercooler, I am sorry my bad on that! You must know your stuff!
Intercooler setup Pic Request and Questions Semper_Fi MKIII Supra 8 07-29-2011 08:44 PM
Intercooler pipe kits? hohum MKIII Supra 2 07-26-2006 05:26 PM
