Old 08-02-2010, 03:18 PM   #1
War
War is on a distinguished road
Default How to Gain a 300-400KW. :)
Hi Guys, I'm new here. I just got my 1995 Jza80 twinturbo Supra from Japan.
I just wanna know what is the the best Upgrades to put in my supra
to gain a power between 300-400KW. I just wanna get some Idea and Option before i go to a mechanic so they wont rip me off. hehe..
My Upgrade at the moment are:
18" TE37 works rims
Blitz SpecNur exhaust
Strut Bars [ Front and Back ]
Pivot Turbo Time
Blitz Boost Gage
Trust LS spec Intercooler
Tein CoilOver [ Bloody Stiff ]
Now I wanna start in the Engine so Hope you PRO guys can help me. Thanks! P.S. i live in Western Australia. Just incase somebody is also from here. : Thanks again! Rok On!
War is offline   Reply With Quote
Old 08-03-2010, 02:18 AM   #2
18" TE37 works rims
Pivot Turbo Time
Blitz Boost Gage
1) As you know (I hope ), the rims, strut bars, turbo timer and coilovers won't help with your horsepower increases.
2) At the 300kw level, the upgraded exhaust won't make any difference either. At the 400kw level, you may notice a small difference.
3) Don't get a rear strut bar - it's a waste of $, given the construction of the jza80 chassis
4) What you're missing from your list is: downpipe, GReddy BCC (to eliminate fuel cut), and a boost controller (to raise the boost).
More info here:
http://www.mkiv.com/faq/faqtt.html#bpu1
Note: My recommendations are all based on US-spec. Japanese-spec is pretty similar, but not a 100% match. For example, I believe an HKS FCD will work just fine on a Japanese-spec Mkiv (instead of the GReddy BCC), but I'm not totally sure about that. However, the downpipe and boost controller (or boost increase modification) are musts.
Old 10-22-2010, 04:45 PM   #3
kylej
kylej is on a distinguished road
Too add to what he said, BPU (basic performance upgrades) are known to give the best hp/$ ratio. They are the Greddy BCC (highly recommended from what I've heard), exhaust, intake, bov, boost controller, and small things. Then there is BPU+ which is where you add things a big larger, I think Cam gears fall into this, and BPU++ is where you have everything except bigger turbos, fuel systems, and big things like that. In good conditions i've heard of just plain BPU supra's getting 380-410rwhp on a dyno, of course you lose some power going to the streets but that is nothing. if you google supra build there will be tutorials and/or guides that will help you get the highest hp/$ ratio while keeping your car practical (not running 22psi on stock turbos). Because you have a Jdm car the dicks turned the boost down, restricted with exhaust and stuff unlike the usdm which start at 330hp, jdm start at 280, however with bpu upgrades both cars will be exactly the same, you will just notice a lot bigger change from jdm-bpu than usdm-bpu
kylej is offline   Reply With Quote
Old 10-23-2010, 01:50 PM   #4
An aftermarket exhaust is not necessary for BPU.
USDM starts at 320hp (not 330).
http://www.mkiv.com/specifications/9.../1993promo.jpg
obx headers hp gain? twan Shops & Part Reviews 1 01-30-2010 01:38 AM
What is the cheapest, fastest way to gain BIG HP? idoke MKIII Supra 19 10-05-2006 05:19 PM
New Exhaust Power Gain? or Power Lose? supraman121 MKIII Supra 0 08-31-2006 12:29 AM
