Old 05-09-2010, 10:21 PM   #1
Bl@ckh3art
Bl@ckh3art is on a distinguished road
Default Buying a Mk4 supra! it has a missing ignition signal. Is dat major?
Should i be worried about that problem? Is that a major issue? How much would it cost to repair! My understanding of that issue is that it have problem turning on. When driving it could shut off! can anybody give me info about that! or if anyone had this problem?
Bl@ckh3art is offline   Reply With Quote
Old 05-10-2010, 04:29 AM   #2
What is the code that it is showing? How do you know it is missing the ignition signal? This is a pretty rare problem...
Old 05-20-2010, 01:22 AM   #3
Bl@ckh3art
it show code 14! dats what it says on the scanner when shown!
Old 05-21-2010, 02:06 PM   #4
Do you have the TSRM? It shows the troubleshooting steps to take for each code...
If you do the fix yourself, it should not be that expensive to fix unless your ignitor or your ecu is bad.
Old 05-26-2010, 01:15 AM   #5
Bl@ckh3art
thanks! im going to check that out!
Thinking of buying a used modified Supra holliskingdee MKIV Supra 1 12-12-2009 12:45 PM
I'm looking at buying a Supra (new to forums) feelthejoy MKIV Supra 0 07-02-2009 07:25 PM
buying a supra docvtak MKIV Supra 6 11-16-2005 01:29 PM
