Old 04-06-2010, 12:38 AM   #11
matt1993supraTT
matt1993supraTT's Avatar
matt1993supraTT is on a distinguished road
made some head way on the car this weekend, spoke with dusty at MVP ( awesome guy!) a and we both seem to think its the a mass air flow sensor issue luckly for my bro i have a car just like his so i will swap mine over to his and give it a try
matt1993supraTT is offline   Reply With Quote
Old 04-06-2010, 01:18 AM   #12
I'm glad Dusty agrees with me:
...I agree the maf configuration needs to be changed back to oem - this is a strong suspect as the first troubleshooting step to take...
Please say 'hi' to him for me, next time you talk.
P.S. The current post-turbo MAF configuration could be the very reason that MAF got ruined (if that's the problem)... excess heat or oil from the turbos could easily mess up the sensor. Please keep that in mind before you swap yours into a questionable configuration...
Old 04-10-2010, 07:49 PM   #13
matt1993supraTT
agreed i dont want to screw up my maf sensor..he's order a AEM today so we might not ever know what was wrong with it
Old 04-11-2010, 06:11 PM   #14
matt1993supraTT
ok i need somone to explan! i pulled the car out today hosed off all the dirt hit the engine with some grease lighting and chagned the oil..then took it down the road the car spooled up but didnt die, side note i had the fuel preassure WAY to high, turn it down a bit took it back out and it ran GREAT!! like a monster so whats the deal went from being unable to boost to a friggin rocket??
Old 04-11-2010, 07:35 PM   #15
If your fuel pressure was "WAY too high", how was the a:f ratio "around 12.9 before it dies"? Something doesn't add up.
Old 04-11-2010, 08:01 PM   #16
matt1993supraTT
i had adjusted on it before today, when the car was brought in i think it was set at 25 pounds and i had turned it up to 35 so i went up 10 pounds from, but after i readjusted it it stayed right at 13.1 under full boost
Old 04-18-2010, 02:45 PM   #17
matt1993supraTT
well it's not the mass air flow sensor back to square one. this car is driving me crazy i have no other idea what it could be i've changed or adjusted every sensor that it was pulling codes for.
Old 04-18-2010, 03:39 PM   #18
Did you put the MAF back to the oem configuration (pre-smic/fmic)?
Old 04-18-2010, 08:45 PM   #19
matt1993supraTT
yes sir its back to the oe location
Old 04-20-2010, 02:12 AM   #20
Does it still die at 4000 rpm?
boost hits, cars dies chillin943 MKIII Supra 10 08-19-2009 05:46 PM
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
