Old 08-14-2009, 11:21 AM   #4
Originally Posted by krahs912 View Post
im useing Apex i AFC Neo Fuel Management i checked fuel pressure today and it does not drop off at high rpm. (fp 50psi) i did find today that the boost goes from 17psi to 10psi when the problem happens so i think i am feeling a power loss. what could cause such a boost drop? it is a instintanious drop and comes right back. its like a switch. i can run 18psi in 1st and 2nd gear no prob. i think it has to do with holding boost for longer periods of time. thanks for any help you can provide.
Does the Apex i AFC Neo Fuel Management unit have a provision to eliminate the fuel-cut in the 2jz-gte oem ecu (i.e. eliminating the need for a GReddy BCC or HKS FCD)?
The boost drop could be caused by a loose or split intercooler hose - it may overlap enough to hold 10psi, but push apart at levels higher than that. Another may be an improperly-functioning BOV.
Engine cuts out igosaur MKIII Supra 9 02-07-2019 07:09 PM
engine cuts and dies uddinf MKIII Supra 9 09-06-2009 06:56 AM
Question about Slick 50 engine protection! 88 MARK3 Non-Generation Specific Questions 15 07-15-2006 04:04 PM
