Old 09-27-2009, 05:14 PM   #11
RZ-rix
RZ-rix is on a distinguished road
Default Greddy Emanage
Spoke with my tuner today , I mentioned buying the Greddy Emanage piggy back, and he tolld me its not worth it , mentioned some issues with the way piggy backs actually work , and to just buy a stand allone AEM for tuning . So I think I'l save up and pick up a AEM .
RZ-rix is offline   Reply With Quote
Old 09-27-2009, 05:58 PM   #12
Durandal
Durandal's Avatar
Durandal is on a distinguished road
You mentioned pulling your trac fuse to remove your speed cut. That should not work on a JDM afaik.
Durandal is offline   Reply With Quote
Old 09-27-2009, 09:11 PM   #13
Agreed.
http://www.rhdjapan.com/jdm-low/HKS-...er-Type-I-9835
Old 09-29-2009, 12:35 AM   #14
RZ-rix
Default Speed limiter
I read that the trac fuse will eliminate the speed limiter and traction controll if removed on Japanese speced Supras.
Old 10-01-2009, 10:30 AM   #15
Where did you read that?
Old 10-16-2009, 05:49 PM   #16
RZ-rix
Default Trac fuse
Pulled my Trac fuse , and it does eliminate the traction control and 180kmh speed govenor , on my Japanese spec 94 TT Supra.
Old 10-17-2009, 01:37 AM   #17
Durandal
Durandal's Avatar
Is it limited with the fuse in? You might just already have speed delimiter piggyback device installed by your ECU.
Old 10-17-2009, 04:10 AM   #18
RZ-rix
Yes fuse in limiter is working at 180kmh , once I remove the Trac fuse my traction light flashes on and off , and no more speed limit or traction control.
Planning on upgrading to 7M-GTE bambam MKIII Supra 1 09-20-2007 02:14 AM
Upgrading turbos on a 1jz supradaddy0803 MKIII Supra 1 07-16-2007 10:08 PM
upgrading intake and exhaust! tone loc MKIII Supra 28 04-17-2007 06:57 PM
upgrading my turbo Supra4turbo20 MKIII Supra 6 01-20-2006 04:42 PM
upgrading 1987 turbo Prez420 MKIII Supra 22 09-24-2005 03:03 PM
