Old 09-29-2009, 12:35 AM   #1
RZ-rix
RZ-rix is on a distinguished road
Default Speed limiter
I read that the trac fuse will eliminate the speed limiter and traction controll if removed on Japanese speced Supras.
RZ-rix is offline   Reply With Quote
Old 10-01-2009, 10:30 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Where did you read that?
Life begins at 30psi.
Old 10-16-2009, 05:49 PM   #3
RZ-rix
Default Trac fuse
Pulled my Trac fuse , and it does eliminate the traction control and 180kmh speed govenor , on my Japanese spec 94 TT Supra.
Old 10-17-2009, 01:37 AM   #4
Durandal
Durandal's Avatar
Durandal is on a distinguished road
Is it limited with the fuse in? You might just already have speed delimiter piggyback device installed by your ECU.
Durandal is offline   Reply With Quote
Old 10-17-2009, 04:10 AM   #5
RZ-rix
Yes fuse in limiter is working at 180kmh , once I remove the Trac fuse my traction light flashes on and off , and no more speed limit or traction control.
Planning on upgrading to 7M-GTE bambam MKIII Supra 1 09-20-2007 02:14 AM
Upgrading turbos on a 1jz supradaddy0803 MKIII Supra 1 07-16-2007 10:08 PM
upgrading intake and exhaust! tone loc MKIII Supra 28 04-17-2007 06:57 PM
upgrading my turbo Supra4turbo20 MKIII Supra 6 01-20-2006 04:42 PM
upgrading 1987 turbo Prez420 MKIII Supra 22 09-24-2005 03:03 PM
