Old 04-13-2009, 11:42 PM   #1
MikeC10305
MikeC10305 is on a distinguished road
Default EGR System cost
I was wondering how much it will cost me for an EGR system for my JDM 94 supra, so that I can pass EPA tests... THANKS
MikeC10305 is offline   Reply With Quote
Old 04-14-2009, 12:20 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Honestly, not much at all for most of the components. Lots of mkiv owners in the US have torn everything off (eg EGR valve, egr pipe, vsv, etc.) as part of their single turbo install. ...BUT, there are two parts that you will have difficulty with:
1) The US-spec cylinder head: It has a hole drilled from the #6 exhaust runner to the backside of the head and then another hole drilled towards the front of the head to beside the #6 intake runner. It also has several threaded bolt holes for the EGR plate that goes over the back of the head to route the exhaust gas to the intake runner hole. Lastly, there are two threaded stud holes for the EGR mount on the intake runners.
2) Used us-spec lower intake runners are rare, since they're often used to construct aftermarket intake plenums.
Without all of this, building the EGR will be somewhat difficult.
I'll end my post with some (hopefully) good news for you: As long as you're not in California, you should be able to pass a tailpipe smog test without an EGR system (as long as you have the oem catalytic converters in your downpipe and exhaust). Hopefully NY does not require a visual inspection of oem components.
Life begins at 30psi.
Old 04-14-2009, 07:58 AM   #3
MikeC10305
How can I go about finding what the requirements in my area are???
Locating Replacement Cruise Control System Supra 340 Non-Generation Specific Questions 1 09-09-2009 05:32 PM
Cost effective? Need some major advice here! Devoted2Supra MKIII Supra 6 04-13-2009 02:35 PM
Questions about the oem fuel system Magical Trevor MKIV FAQ 7 08-19-2007 04:40 PM
exhaust system kewlcoconut MKIII Supra 10 11-02-2005 07:46 PM
