Old 02-01-2009, 05:05 AM   #1
twiztid
twiztid is on a distinguished road
Default HELP i think i fried something in my engine
My brother was jump starting the 1993 supra tt and put the positve on the negative side and vice versa. I blew everything. Now we cant figure what it damaged. Anybody ever heard of that happing and what did they damage. Its been down for awhile now. we havent got around in trying to figure it out. Please help
twiztid is offline   Reply With Quote
Old 02-01-2009, 06:10 AM   #2
supraman911
supraman911's Avatar
supraman911 is on a distinguished road
I dont have the answer but I just want to say I'm sorry for ya
1.1995 Toyota Supra TT
2.Toyota AE86 Trueno
3.Mazda MX-5
4.Mazda RX-7
5.Mitsubishi Lancer EVO X Ralliart
LOVE these CARS
supraman911 is offline   Reply With Quote
Old 02-03-2009, 11:13 AM   #3
pwpanas
Supra Owner
pwpanas's Avatar
No biggie. The main fuse in your fuse box is blown. It's at the front corner, closest to the engine, with a clear cover. Toyota is the only place to get a new one, afaik.
Life begins at 30psi.
Old 02-03-2009, 08:28 PM   #4
twiztid
Default we check that fuse with clear cover and replaced it
We replaced that fuse but we still are not able to start the car. what other things could we check.
Old 02-04-2009, 04:50 AM   #5
pwpanas
Supra Owner
pwpanas's Avatar
I've had this happen before, and replacing that fuse fixed the problem. If you can, please post a digital pic of the fuse you replaced. It should look just like this (edited) picture that I've attached...right?
Old 02-06-2009, 03:33 PM   #6
twiztid
Default ok I check that fuse and its not it
I switch that one out originally. Would it be possible that the igniter got fried. i believe its the little black box right above the fuse box.
Old 02-06-2009, 10:04 PM   #7
pwpanas
Supra Owner
pwpanas's Avatar
Extremely doubtful, but if you've already replaced the fuse I indicated and things still don't work, then I guess anything's possible at this point. Before you buy a new ignitor, I'd find another MKIV Supra TT in town with a firendly owner that will allow you to swap his in to try it. I'm telling you though, it's more likely to be something VERY basic, since that fuse is supposed to blow (and that's the only thing that's supposed to happen) when you put the battery cables on backwards. After you replaced that fuse, did anything at all happen differently? For example, do any lights come on now, even if it still doesn't start? If possible, post a video online (via youtube, etc.) with you trying to start your Mkiv in its current state - be sure to get a closeup of the engine bay and the dash. It's tough to diagnose & troubleshoot problems like this remotely, but I'm willing if you are.
Old 02-07-2009, 04:21 AM   #8
twiztid
Default thanks for all your help
Well when we jump start it because the battery is dead the lights come on it cranks over and you can smell fuel. we did the self dianostic check awhile back and the code came up as fuel pump. i will run the code check again or i will have my brother do it on sunday. Its his car im just trying to help him out. I feel bad for the car because its sitting there collecting dust.
Old 02-07-2009, 04:25 AM   #9
twiztid
Default one more question
could and igniter from a non turbo mkIV work?
Old 02-11-2009, 10:55 AM   #10
pwpanas
Supra Owner
pwpanas's Avatar
Unfortunately, no.
