Closed Thread
Old 11-13-2008, 10:00 PM   #1
nvr2lo88
nvr2lo88 is on a distinguished road
Default I Have A Off Base Question Please Help Me
Okay Now Maybe I'm Not Asking The Right Question Or I Am Way Off Base But I Have A 88 Gmc S-15 Same Thing As A Chevy S-10 And I Want To Install A 2jz Or 1jz Motor I Can Get The Motor Tranny Ecu And Full Engine Harness But How Can I Get It To Work What Will I Have To Do I'm Mind Is Blocked This Is My First Engine Swap Like This And I Can Not Wrap My Head Around It So Please Help Me Open To Any Suggestions And Comments Do I Need To Get A Wiring Harness Converter Nobody Even Makes On I Know Of Or I Was Thinking Of Changing The Dash But Not Right Away So Please Get Me Out Of This Jam You Can Also E-mail Me At nvr2lo88@yahoo.com Thank You
nvr2lo88 is offline
Old 11-14-2008, 08:36 PM   #2
I can help you with the 2jz-gte part, but I have no idea what to do aout the S-15.
You can control the 2jz-gte with an mkiv supra turbo wiring harness and either an oem mkiv tt ecu, or an AEM ecu. I'm fairly certain that you'll have to do lots of custom wiring to "adapt" the oem mkiv supra turbo wiring harness to your S-15...either that, or just mount the 2jz-gte ecu inside the engine bay and give it lots of heat shielding, etc. For more info on the mkiv tt oem ecu, there's always the TSRMs.
If you have any more 2jz-gte questions aspect of your project, please feel free to ask - I'll do my best.
pwpanas is offline
Old 11-14-2008, 08:50 PM   #3
Dan Swanson
Dan Swanson is on a distinguished road
Default OFF base question
Phil,
You gave a good answer regarding engine swap into the S10.
He has work cut out for him.
I was looking for your address when I saw your reply.
I am a new to Supra forum. I am a slow typist. Many time I have timed out while responding on the forum. How much time to you have to complete a reply. Is there any way to save a reply in progress so you do not lose it??
In fact I was sending a reply to you and lost it due time?
Keep up the good work.
Dan Swanson
Dan Swanson is offline
Old 11-16-2008, 02:39 PM   #4
Originally Posted by Dan Swanson View Post
Phil,
Dan Swanson
I'll check into the timeout.
Thank you for the kind words regarding my response!
pwpanas is offline
Old 11-17-2008, 06:27 AM   #5
Dan Swanson
What is your connection, does it happen on any other forum?
It's quite a difficult issue to chase.
suprra_girl is offline
Closed Thread
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
I Have A Off Base Question nvr2lo88 Non-Generation Specific Questions 1 11-15-2008 11:57 PM
