Old 09-29-2008, 12:49 AM   #41
1993suprawr
1993suprawr is on a distinguished road
what about if i just go drive for like a hour but not like drive it hard would i need to use the turbo timer or like if im driving fo rlike 10 mins and come home would it matter if i still have it on for like 50 seconds..and what engine oil do u guys prefer...
1993suprawr is offline   Reply With Quote
Old 09-29-2008, 02:27 AM   #42
mnewxv
mnewxv is on a distinguished road
theres really no reason to not use it, just 'set it and forget it'. but chances are if your just driving around, you wont get into boost, and the turbos wont heat up much, so no, wouldnt need it if your not getting into boost.
mnewxv is offline   Reply With Quote
Old 09-29-2008, 02:50 AM   #43
1993suprawr
okay thanx! but i still need to figure out what engine oil i should use cause the cars leakign a bit but im getting it fixed on tuesday and so i just want to put more engine oil iin there in case
Old 09-29-2008, 03:09 AM   #44
1Chin3seBoi
1Chin3seBoi is on a distinguished road
i used royal purple 15 40
also i was wondering what type of engine oil would u guys prefer thati used a name and brand would be good cause i gotta go buy some cause its pretty low thanx hopefully someone can answer me really soon
HKS/GREDDY/SARD/CUSCO/VOLKS
1Chin3seBoi is offline   Reply With Quote
Old 09-29-2008, 03:36 AM   #45
1993suprawr
okay cool thanx alot
Old 10-01-2008, 02:04 AM   #46
Don't use 15 40. The engine's bearing clearances and the oil pump are all spec'd for 10w30. Amsoil is best, followed by redline and then royal purple.
Old 10-01-2008, 05:52 AM   #47
1Chin3seBoi
ya i think 10 30 is good..
reason y i bought 15 40 cuz they ran out of 10 30 last time lol
really Amsoil is good? never that brand before
i tho royal purple is the best
Old 10-03-2008, 09:36 AM   #48
1993suprawr
shiat i used 15w30 royal purple they only had that but ill be sure to use that other stuff next time? is this very bad for the car or what?
Old 10-03-2008, 09:40 AM   #49
1993suprawr
and i was planning on buying this for my car since i dont have any gauges in it Blitz SBC I-Color Electronic Boost Controller with LCD Display should i not worry abotu that stuff or is it okay to buy it and get someone to install it, or what other gauges would i need? or is this thing good enough...haha just thougth i would since it looks pretty sweet lol it shows like "- The color monitor can show 12 kinds of data, which are BOOST, TACHO, SPEED, POWER, TEMPERATURE (water/oil), OIL PRESSURE, FUEL PRESSURE, AIR/FUEL ratio and External Voltage Input 1-3 (needs optional external voltage input harness). Maximum 6 kinds of data can be shown on the screen at the same time. (Please note that temperature sensors, pressure sensors, and A/F unit are optional items.)" i donno just give me a heads up on what type of gauges i should go for and some links so i can buy some like whatever ones that are important, thanx
Old 10-03-2008, 09:45 AM   #50
1993suprawr
since i have no clue where to start and what to do to the car slowly piece by piece getting it upgraded
