Old 07-18-2008, 01:30 AM   #1
sleeperz
sleeperz is on a distinguished road
Default AEM software question
I just purchased a supra and it has an aem in it. im very familar with other systems out there. The tables read in m/s pulse with etc. I seen someone else's computer and they had it setup to read actual air fuel. The dash board would show it as well as the fuel map, target a/r, etc. I have been playing with it for an hour trying to figure it out. downloaded new software from aem but cant seem to get it. Can someone help configure my computer so it will show actual a/f. then the fuel map with show rpm on the horizontal colum and a/r on the vertical. right now its rpm and load
sleeperz is offline   Reply With Quote
Old 07-18-2008, 03:21 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Does your Supra also have a wideband?
Life begins at 30psi.
Old 07-18-2008, 03:46 AM   #3
sleeperz
yes it does. Also the knock control and o2 correction where do i find those? Not sure if its software or needs to be configured
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
turbo or not ??? That's the question ... sausa MKIV Supra 7 03-30-2007 02:22 AM
