Old 03-03-2007, 10:07 AM   #1
CKeaton614
CKeaton614 is on a distinguished road
Default Swapping Trany
I'm thinking of buying a 94 TT but it's automatic i got a good price on it but I really want a 6 speed. Anyone know how hard it would be to swap out the trany? Or if i should just keep looking for one with a 6 speed. This 94 only has 80k and the guy is letting it go for 18k. It's hard to pass up..
CKeaton614 is offline   Reply With Quote
Old 03-03-2007, 03:14 PM   #2
All the info you need is at this link:
http://www.mkiv.com/techarticles/aut...wap/index.html
Ime, it'll definitely cost much more than the difference (parts+labor), so you're much better off to keep looking for a 6spd if that's what you need.
As an additional item to consider, note that an automatic is significantly more consistent, as well as being significantly faster in the 1/4 mile. Of course, it's also a lot less difficult for the driver. If you want to drag race your 94 TT, you might want to reconsider your desire for a 6 speed. On the other hand, if you want to roadrace (which is what the Mkiv Supra's jza80 chassis & suspension was designed for), I agree a 6 speed is a much better choice.
Old 07-09-2009, 04:57 PM   #3
brianpa25
brianpa25 is on a distinguished road
Default tranny swap
I came across a guy, who bought an auto and claimed it was a bad choice, and he spent 19k to replace the auto with a 6 speed tranny. Granted he didn't spend 19k just to replace the auto for a 6 speed cause he had the cash laying around, he screwed up the tranny with an aftermarket turbo. Which is why he told me to look into 6 speed, said the auto can't handle upgraded turbo's. ???? Not sure about the truth in that either.
brianpa25 is offline   Reply With Quote
Old 07-13-2009, 05:20 AM   #4
For roadracing, an auto tranny is a bad choice. It's all about your application, not an absolute bad-or-good of one tranny over another.
The upgraded auto tt tranny will handle a small or even mid-size (eg. T67) single turbo and moderate boost levels. For high boost and a big turbo (eg. T76+), you'll need either a 6spd or a TH400.
have 163k on trany and engine t.ortlieb@peoplepc.com Non-Generation Specific Questions 0 04-06-2008 03:23 AM
Boosting a 7MGE or swapping it out. Knightryder MKIII Supra 12 08-16-2007 04:45 PM
MKIII turbo supra trany ishthemienguy MKIII Supra 4 03-26-2006 04:06 AM
Supra Transmission Swapping alamz2 Non-Generation Specific Questions 0 02-08-2006 06:18 AM
