Old 06-09-2005, 03:01 PM   #2
ddmcse
ddmcse's Avatar
quoted:
for closed loop control of the air-fuel ratio, and fault sensing of the catalytic converters, the exhaust system is equipped with two lambda sensors. one mounted ahead of the first catalytic converter, the other o2 sensor is just after the 2nd cat. only the 1st o2 sensor provides feedback to the ECU for closed loop fuel trim. apparently the 2nd sensor is used for fault detection of the cats.
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
TPS Sensor and Auto Trans btwilson86 MKIII Supra 5 02-12-2008 07:31 PM
550 injector & lexus air flow troubles o2 sensor? night-rider MKIII Supra 1 09-03-2007 08:52 AM
O2 sensor? rnoswal MKIII Supra 5 08-02-2006 01:53 AM
Knock sensor for an N/A. rnoswal MKIII Supra 2 11-16-2005 05:12 PM
Knock sensor..........ebay. rnoswal MKIII Supra 0 11-06-2005 07:24 PM
