Old 10-11-2007, 04:40 PM   #1
redmaro
Default Hitting fuel cut
Last night I shimmed my wastegate with 5 shimms on each side (aout 8mm). I went and test drove it and I hit fuel cut I really dont know how much boost i was getting since I dont have an aftermarket boost gauge.
So today i took 1 shimm of, so know it only has 4 shimms on each side of the waste gate. Im still hitting fuel cut but it does take a bit longer to hit it. Every time I hit fuel cut i get a check engine light, I pulled out the code and its code 34 which is turbo pressure also known as a boost leak. So is the code 34 im getting normal when hitting fuel cut? or do i have a boost leak?
MK3, Auto, Turbo.
Old 10-11-2007, 08:51 PM   #2
redmaro
Alright now I brought it down to 3 shimms per bolt on the wg. Im still hitting fuel cut.
A little history, a few days ago my car had a real bad missfire. So I took a look at the spark plugs the spark plugs are fouled. And to my surprise the spark plug wire number 6 was burnt at where it makes contact with the spark plug. So I cut the piece off and reconnected it, and my missfire problem was gone. So could it be my spark plugs causing the problem? Or the spark plug wire I fixed? But other than that no missfires at all and the car seems to be running pretty good. O and the spark plugs are fouled because of a rich lean problem I was having but I fixed that now. So what do you guys think? 2 shimms seems like nothing.
MK3, Auto, Turbo.
Old 10-11-2007, 11:17 PM   #3
1988gte
trsm say abnormal boost pressure, so i would say its not a boost leak
Old 10-12-2007, 01:12 AM   #4
redmaro
i would say your wrong.
I found a huge boost leak, it was the lower coupler that holds my ic pipe to the turbo. Problem fixed. Thanks anyways
MK3, Auto, Turbo.
Old 10-12-2007, 04:08 AM   #5
1988gte
yeah old hoses do that, especially when more than stock boost. My car would stall and stumble when my boost leak happened but never got a code. Using shims I noticed that somedays i would get fuel cut and other days i wouldnt. Weather maybe??? Anyway I got a boost controller
Old 10-12-2007, 04:13 AM   #6
redmaro
Yeah I had a big boost leak at where the IC pipe connects to the turbo. Ive also heard that depending on the weather somedays youll hit fuel cut.
MK3, Auto, Turbo.
Old 10-12-2007, 04:14 AM   #7
redmaro
BTW Im running hard pipes.
MK3, Auto, Turbo.
Old 10-12-2007, 04:36 AM   #8
1988gte
Thats where mine went bad also. what hard pipes are you using
Old 10-12-2007, 04:59 AM   #9
redmaro
Im running DIY IC pipes.
MK3, Auto, Turbo.
Old 11-25-2007, 01:36 AM   #10
Spudboy
Spudboy's Avatar
Can you tell me the best way to wire in a Blitz boost controller? Should I wire directly to the battery or somehow to the ignition. If the ignition how or somewhere else...how?
car cranks, but no fuel or spark mustangtw5901 MKIII Supra 17 04-30-2008 07:48 PM
Fuel Octane scruffboy Non-Generation Specific Questions 3 09-08-2006 06:49 PM
