Old 10-09-2007, 04:51 PM   #1
go.stfu
go.stfu's Avatar
go.stfu is on a distinguished road
Default Partially Attach Flywheel
Is it safe to attach the TC to the flywheel by only 5 of the six bolts for a 15 minute test to see if the engine is working?
One of the holes on the flywheel was bent by a screwdriver holding the wheel in place.
In a week I'll have a new flywheel but the engine must be tested in the next couple of days.
Thanks for the info.
1985 manual (r.i.p) -- 1989 automatic (new)
http://www.cardomain.com/ride/2635827
go.stfu is offline   Reply With Quote
Old 10-10-2007, 06:22 AM   #2
86SupraMan
86SupraMan's Avatar
86SupraMan is on a distinguished road
Ehhh... i dont think 5/6 bolts is safe, it wouldnt have the same pressure all around, which would make it uneven and possibly dangerous, IMO.
best to get a 3rd opinion here.
86.5 Toyota Supra
((Current Mods)) :
-Slotted/Crossdrilled Rotors
-K&N Filtercharger
-H4 Projection light Conversion
-Magnaflow Catback Exhaust
-=Mods to do=- :
-Rust Repair
-Bodykit
-Paintjob
-Engine work
-Suspension
-Wheels
-Intake (Semi-Done)
-Exhaust
86SupraMan is offline   Reply With Quote
Old 10-10-2007, 04:13 PM   #3
I'd agree... The 6 bolts would keep the torque converter flush against the flywheel. With only 5 of them, you run the risk of something flexing, and probably causing some damage.
Old 10-10-2007, 08:09 PM   #4
go.stfu
go.stfu's Avatar
Went and grabbed one off of ebay -- decided the risk probably wasn't worth it.
Old 10-11-2007, 03:49 AM   #5
twerb089
twerb089's Avatar
twerb089 is on a distinguished road
i dont see what the big deal is if your just going to start it and let it idle... flex plate should not be moving that much at lower rpm
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
twerb089 is offline   Reply With Quote
Old 10-11-2007, 03:06 PM   #6
86SupraMan
86SupraMan's Avatar
the big deal is that if your flywheel isnt properly attached, even it it doesnt move that much, it still runs the risk of wobbling and you REALLY dont want that because it will just cause needless damage to your vehicle, its like... trying to drive with 3 wheels on your car. you CAN do it, it just isnt Safe/good for your car.
86.5 Toyota Supra
((Current Mods)) :
-K&N Filtercharger
-=Mods to do=- :
-Rust Repair
-Bodykit
-Paintjob
-Engine work
-Suspension
-Wheels
-Intake (Semi-Done)
-Exhaust
Who here is running a aluminium flywheel, or has run one? Chambers MKIII Supra 2 08-31-2007 06:33 PM
Flywheel resurfacing gpgtp_22 Non-Generation Specific Questions 2 03-20-2007 09:04 PM
racing flywheel Jeff_5_7 MKIII Supra 7 02-14-2007 04:31 AM
clucth,trans,and flywheel question tone loc MKIII Supra 0 09-28-2006 08:43 PM
