Old 10-05-2007, 03:33 PM   #1
big'in
big'in is on a distinguished road
Default need help
88 turbo ... no fire.. what do I need to check ??
big'in is offline   Reply With Quote
Old 10-05-2007, 03:58 PM   #2
dcrusupra
dcrusupra's Avatar
More info please. And check the codes if any.
http://www.toyota-supra.info/forums/...read.php?t=323
^^^How to pull codes^^^
New Rebuild
My CarDomain
Old 10-05-2007, 07:33 PM   #3
west_side_supra
west_side_supra's Avatar
TPS
Main relay box - relay ACC 1 or maby 2
coil pack
coil pack harness
igniter
spark plug wires arnt connected
thats what i can think of off the top of my head
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 10-07-2007, 04:14 PM   #4
86SupraMan
86SupraMan's Avatar
86SupraMan is on a distinguished road
Explain yourself, are you SURE its the plugs? did you check the fuel?
86.5 Toyota Supra
((Current Mods)) :
-Slotted/Crossdrilled Rotors
-K&N Filtercharger
-H4 Projection light Conversion
-Magnaflow Catback Exhaust
-=Mods to do=- :
-Rust Repair
-Bodykit
-Paintjob
-Engine work
-Suspension
-Wheels
-Intake (Semi-Done)
-Exhaust
86SupraMan is offline   Reply With Quote
