#1 |
Can someone give me specific part numbers or description and/or where I can get the proper AFM and 550cc injectors for my '88?
#2 |
I'm kinda wondering too about the lexus afm and injectors. Right now i'm hitting fuel cut on my shimmed wastegate and 57 trim but i don't know where to go next.
#3 |
well i have gotten almost everything from ebay guys. alot of other places that will cover injectors, AFM, and adj fuel press reg. will be
Welcome to SupraSport.com ltd - We don't make the car, we make it faster! Performance Parts Aftermarket and Racing eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices here are some links to those items here is a complete kit includes AFM/INJ/INJ clips this will give you most items, after this you just need the adj. fuel pressure regulator and you'll be set. ADJ. press. reg kit LIPP 1 this allows you to control the amount of fuel entering your fuel rail, it will make it so you are going to be killing your engine with an overflow of fuel and possibly burst your lines. although the walbro pump is very stong and can take alot, i still recommend this adj. pressure kit. if you really want there is another removal system to get rid of your Fuel pulse thingy, i really dont know what that does but its ugly and not needed. and here a link for that kit to. fuel pump 1 2 there are diffrent types of pumps availible, the walbro is the easyist one though, it will go right into your tank just like the stock one. pushes 300% more than your stock. and will allow you to do your 550cc/+ injector system , now dont order the venom injectors, they have been highly known to stick, and this can make a really big issue. so i repeat DONT ORDER VENOM INJECTORS, RC are the best so far. PTE "precision turbo engine" are the next best. i am running the pte 550 and are sweet so far. injectors 1 - supra sport 2 - ebay - 1000cc injectors availible from these guys also these will allow you to use your pump to its full potential, and plus they are almost needed when you upgrade to your Lexus v8 afm, i've heard of people not changing the houseing but just the sensor and running somewhat lean. i dont know this for fact but its just something i have recently heard, DONT ORDER VENOM INJECTORS THEY STICK AND WILL CAUSE MORE PROBLEMS. AFM 1 - supra sport 2 - these are used and imported from jap. but very low mileage and clean and work. for injectors with the lexus afm 550cc are good 680cc are better. but i dont see why you cant go bigger maby even a 750cc like i posted now just to make things even simpler, i will say that i recommend getting a fuel controlling system like the apexi safc "ebay you can find them for like 25$- 100$" all of these items together with forsay the 550cc injectors you should be good up to 450hp-500hp. if it comes down to the point you still are hitting fuel cut then the next item recommended would be getting 1. HKS FCD - fuel cut defender will remove your fuel cut system and if i remember right you should be able to adjust them to were you want your fuel cut to be set. HKS USA Driving Performance - Homepage 2. i should have put this in the list of items because it is very important to watch your Air/fuel ratio when doing anything with your boost and fuel. but recommend any digital system that will use a wideband sensor. not one you tap into your stock 02 sensor. wideband is very accurate warms up faster. and is a real time reading. and very good for tuning may i put. i personally am running a AEM UEGO w/wideband, and so far its pretty sweet, others recommend or use the Powerdex AFX-Air Fuel RatioMonitor now your probably thinking to yourself, damn this is alot of money. but in the end its all worth it. you will get some more horsey's and you will be able to boost up to 18psi "not recommended on your stock ct-26" or 17.99psi so i have been told i'm not sure yet since im still in the process of breaking in my motor :P- - -||____XD hope i helped you all out with your questions. i'm willing to help to what i know so ask again and ill reply back for you
![]() 7MGTE - 500hp never dyno'dexhaust: 3inch pipes no cat/powerhouse manifold/garret gt47 18psi/HKS SS racing wastegate fidenza cam gears intake: PHR 4inch intake/K&N filter/3 inch intercooler/ pipeFMIC/greddy type R bov/ fuel: 550cc PTE/ walbro 255lp / Aeromotive adj pressure regulator transmission: Fidenza flywheel/ACT extreme kit electronics: map ecu 1 / HKS EVC 9 gauges:boost,EGT,oil temp & pressure/aem AFR Last edited by west_side_supra; 12-06-2007 at 09:43 PM. Reason: forgot information |
#4 |
Great info west side. Thanks a lot.
What is the need for the new AFM? Looks to me like it's just a little larger bore, but we still use the same actual original sensor. Would you expect I would see a benifit with just 550cc injectors? I have the fuel cut defencer on but I think it still cuts at about 12 psi. May not be set up correct. |
#5 |
i got a question
i checked the replacement afm they said its a copy of the lexus afm which wont come with any of the electronics of the lex afm itself its says you have to reuse the honeycomb and the black box? doesnt the lexus afm has diffrent electronics than the ones that came from the 7mgte? or is it jus the size of the afm that changes?
http://www.myspace.com/supra_2nr ![]() Into Bikes now,, apparently the supra couldnt kill me, so my zx6 might lol |
#6 | |
mmm like i said the houseing of the AFM is bigger on the lexus version compared to the 7m version. replacing the honey comb? uh i dont know if you can even do that, hell if my honey comb broke i would just go and get another AFM and the black box is the sensor itself, and yes totally different, just has the same connection as the 7m, so its just a plug and play
![]() 7MGTE - 500hp never dyno'dexhaust: 3inch pipes no cat/powerhouse manifold/garret gt47 18psi/HKS SS racing wastegate fidenza cam gears intake: PHR 4inch intake/K&N filter/3 inch intercooler/ pipeFMIC/greddy type R bov/ fuel: 550cc PTE/ walbro 255lp / Aeromotive adj pressure regulator transmission: Fidenza flywheel/ACT extreme kit electronics: map ecu 1 / HKS EVC 9 gauges:boost,EGT,oil temp & pressure/aem AFR |
#7 | |
The Lexus AFM does NOT come with the black box sensor. It says to use the original 7M-GTE box/sensor. So it appears all we would be buying is the metal AFM housing and transfering the original honeycomb and sensor to it. Maybe the original sensor detects more air thanks to the larger AFM housing, compensates for that in combination with fuel cut defencer allowing more fuel, and the now larger injectors gives more fuel. Result for me I hope is...larger turbo + boost controller + fuel cut defencer + larger injectors + larger AFM housing + HKS intake = more HP. Does this all make sense? |
#8 | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| 550cc injectors | frostburn | MKIII Supra | 1 | 08-18-2008 04:46 AM |
| 550cc and lexus afm | supradrift | MKIII Supra | 2 | 07-02-2007 10:58 AM |
| 550cc rx7 high impedance injectors? Suppra Girl? | rnoswal | MKIII Supra | 9 | 05-03-2006 01:36 PM |
