Old 10-04-2007, 10:41 PM   #1
denny2hand
denny2hand is on a distinguished road
Question Steering issues
So the other day I'm driving home and by the time I get home the steering is pretty stiff and it's whining a little louder than normal. I park it and go inside. Today I checked the fluid and it looks fine so I start it and head for work. It's still whining but driving normal. About 15 minutes into the drive it starts to get harder to turn. By the time I get to work it's really hard to turn. It's a 45 minute drive to work. I pop the hood at work and my reservoir is empty! I look down and see fluid all around the bottom of the engine bay. What's the most likely problem? Bad pump that possibly caused a leak somewhere? Or busted line? It is weird that the warmer the car got the harder it was to turn. What do you think guys?
denny2hand is offline   Reply With Quote
Old 10-05-2007, 03:07 AM   #2
mrnickleye
mrnickleye's Avatar
Wink
It got hard to turn because your fluid was going out of the pump. Check the 2 ends of your steering rack. You may have blown a seal out one end. Like I did 4 years ago.
Old 10-07-2007, 04:16 PM   #3
86SupraMan
86SupraMan's Avatar
86SupraMan is on a distinguished road
if you noticed it getting harded the night before you should have started checking around, not giving you shit just sayin,
86.5 Toyota Supra
((Current Mods)) :
-Slotted/Crossdrilled Rotors
-K&N Filtercharger
-H4 Projection light Conversion
-Magnaflow Catback Exhaust
-=Mods to do=- :
-Rust Repair
-Bodykit
-Paintjob
-Engine work
-Suspension
-Wheels
-Intake (Semi-Done)
-Exhaust
86SupraMan is offline   Reply With Quote
Old 10-11-2007, 01:12 AM   #4
denny2hand
well, it looks like I've got a busted pump. Finally got some time off from work to crawl under it and look. Fluid is coming out of the shaft. I think the pump is toast. Guess I'll be buying a new one. I took the belt off and it's not really that hard to turn it. Wonder how much power that pump robs? It's been reported that LS1 F-bodies gain 3 tenths in the 1/4 by disabling the power steering. Anyone try this on a Supra?
Dennis
'89 N/A, auto, bright friggin' red and really stock (for now)
Having Trouble Removing the Steering Wheel Chambers MKIII Supra 3 06-30-2008 01:03 AM
Two Issues: Front Brakes and Sporadic Vibration Chambers MKIII Supra 0 11-03-2007 04:15 PM
Steering problems drmmr15 MKIII Supra 17 03-08-2007 09:32 PM
Steering wheel off-centre colin172 MKIII Supra 3 10-06-2006 01:41 AM
What do i need for my steering wheel. paula Non-Generation Specific Questions 1 07-17-2006 01:03 PM
