Old 09-28-2007, 06:07 PM   #1
Jrew
Jrew's Avatar
Jrew is on a distinguished road
Default What exhaust?
Im looking to install a new exhaust system on my 87 supra turbo. I'm looking for a system that provides a real low rumbling tone and allows for power efficiency. The HKS drager system caught my eye a while back and seems like a good possible choice. What do you suggest? Also where is a good site where i can get a good price on these systems?
If you're going to strive, strive to be the best.
Jrew is offline   Reply With Quote
Old 09-28-2007, 08:22 PM   #2
Chambers
Chambers's Avatar
I have a cat back system from HKS, I forget what model it was but it looks similar to the stock Supra system. It gives a nice humming rumbble at low rpm's and sounds like, what I would assume a Japanense mucle car would sound like trough most of the rpm range. I'll try to get a recording of it up somewhere. I also have a test pipe installed.
"Stuck in the 80's"
Old 09-28-2007, 11:03 PM   #3
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
check out the tanabe super hyper medallion, rated at about 93 dbs, it sounded real nice on a sc300 on youtube
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 09-29-2007, 12:22 PM   #4
supradaddy0803
supradaddy0803's Avatar
I have the super dragger and it has a decent tone to it. It isnt quite as load as you would think but it sounds good at a low idle. When you bring the RPM up to like 2500 it has a deep rumble to it and sounds great. With my 1JZ it helps it breathe a lot better.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 10-01-2007, 05:42 PM   #5
Sinistral
Sinistral is on a distinguished road
http://www.toyota-supra.info/forums/...read.php?t=957
Sinistral is offline   Reply With Quote
Old 10-02-2007, 01:51 AM   #6
kwnate
SP58GT
Blitz Nur spec
Nate
Old 10-02-2007, 10:52 AM   #7
ddmcse
ddmcse's Avatar
Cool
ditto
visit my web site for a sound clip of the exhaust
http://www.ddmcse.com/turbo/images/three/DSC00004.WAV
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 10-02-2007, 03:33 PM   #8
supradaddy0803
Oh as for the price thing well a really good exhaust is gonna cost a bit I paid like 670 for my HKS super dragger. I have seen them for more. As for the Blitz NUR spec like nate said I am not sure what you would consider cheap but I think they run like 578 at suprastore I havent seen many places that have them. I think driftmotion has them as well. But it is up to you really just remember just a cat back will only help a little might as weel go like 3" all the way back from the turbo then you will notice it.
1JZGTE swap
JZA70 Front end mod
Old 10-02-2007, 03:35 PM   #9
86SupraMan
86SupraMan's Avatar
86SupraMan is on a distinguished road
if all your looking for is sound but not performance, id suggest Flowmaster. theyre exhausts usually have a nice deep muscular tone to them, sounds good, but doesnt help perform. Myself im looking into a Magnaflow "Race Series" because those are straight through mufflers which allow max flow with min restriction.
86.5 Toyota Supra
((Current Mods)) :
-Slotted/Crossdrilled Rotors
-K&N Filtercharger
-H4 Projection light Conversion
-Magnaflow Catback Exhaust
-=Mods to do=- :
-Rust Repair
-Bodykit
-Paintjob
-Engine work
-Suspension
-Wheels
-Intake (Semi-Done)
-Exhaust
86SupraMan is offline   Reply With Quote
Old 10-02-2007, 07:35 PM   #10
oowee623
oowee623's Avatar
might as well gut out your cat too since you dont live in california
Exhaust for 7MGE XtreeX MKIII Supra 19 03-25-2010 01:39 AM
Exhaust Cat Fitting Bill UK MKIII Supra 4 06-15-2008 11:32 AM
exhaust question (not in exhaust faq) sd88supra MKIII Supra 21 11-28-2006 10:52 PM
Dual exhaust, anyone? lifesnotfair MKIII Supra 13 12-22-2005 10:41 PM
