Old 06-04-2005, 06:13 PM   #1
MK3Turbo
MK3Turbo is on a distinguished road
I have a sweet '89 Supra with a bad turbo. I've done a lot of work on the motor and seeking advice on which way I should go with the turbo... specifically, should I upgrade the CT-26 (rework the housing and larger compressor) or go with a completely new turbo?
This is a daily driver, but I've done the following to the 7MGTE:
- HKS 2mm MHG
- Ported and polished head
- ARP head and rod bolts
- JE pistons
- 3" downpipe and exhaust
- Apexi intake.
I'd like to take advantage of this motor, but I don't want to get silly (keep it a fun, daily driver). I plan to upgrade the fuel system (Lexus AFM + 550 injectors) and stop there. I'd like to preserve the stock manifold/downpipe configuration, if possible, but willing to upgrade if necessary.
Various companies say their upgraded CT-26 turbos (stage 2 / 3) offer outputs of 450 to 600hp. Realistic? (I hear 350 is max). Should I waste my time with an upgraded CT-26?
**What is the best option for the car? A new turbo?
Thanks for your professional advice!!
MK3Turbo is offline   Reply With Quote
Old 06-05-2005, 11:56 PM   #2
i've heard best bang for the buck and power gains and 400hp is realistically achievable is the 60trim ct26
sounds like you've got a bit of a monster there
another thing i would add along with that turbo would be a 255lph walbro fuel pump & fuel pressure regulator... you'll need those specially with the 550's & lexus
Old 06-09-2005, 02:27 PM   #3
i went with an upgrade
i have some before and after shots on my website
http://www.ddmcse.com/turbo/turbo_upgrade.htm
the place upgrades your turbo in 1 day . i think it was 600.00
i have the lexus afm but haven't implemented it yet so i still get cut off
at this point i am a little over 300 hp at the rear wheels (dyno tested not guessing)
mK3 turbo upgrade mrvetten MKIII Supra 7 05-08-2008 03:14 PM
