Old 09-14-2007, 08:34 PM   #1
carfanatic89
carfanatic89's Avatar
Smile Power steering pump
When you put a new power steering pump on or one that has no power steering fluid in it is there some kinda prime process that you have to do to keep the pump from running dry intill it gets fluid, or do you put it in and let it set and seep into the pump for alittle while then start the car. also how would you go about getting air bubbles out of the line.
Supra Engine Powered Dragster
Old 09-15-2007, 04:16 AM   #2
Fill the tank, then start the car, & turn the wheels completely left, then right, about 30X. This will bleed out the air.
make sure tank stays to full line.
Power Steering Pump Whining Chambers MKIII Supra 10 01-28-2010 07:19 PM
power steering pump daluxsrt4 MKIII Supra 1 08-29-2008 02:17 PM
Power Steering Pump and Fluid Chambers MKIII Supra 8 06-29-2008 03:59 PM
Power steering pump.. 89 turbo. 2JZEFINI-17 MKIII Supra 4 03-13-2007 03:23 AM
Help, New Pump Still No Power Steering suprajohnny MKII Supra 2 02-28-2006 06:14 AM
