Old 09-05-2007, 08:15 PM   #1
stanley2001
stanley2001 is on a distinguished road
Default 1jz for 1991 Supra turbo/harness,motor mts issue?
Thanks for all the info in the previous thread. I think I understand a whole lot more about Supras and what can be done with them.
From that, I like the 1jz swap to my 1991 Supra Turbo idea. From what I gather there are 3 modifications necessary. 1) The wiring harness has to be lengthened, even on ones that come uncut with the 1jz.
2) Motor mounts need to be changed. 3) A different drive shaft has to be installed. Does that sound right? Where can I find a drive shaft and motor mounts? Thanks for your help. Stan
stanley2001 is offline   Reply With Quote
Old 09-05-2007, 08:43 PM   #2
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
you have a 91 so the motor mounts are fine, direct fit. since you already have the turbo tranny the driveshaft is fine, the only difference is the bellhousing, and extending the wiring harness isnt necessary.
do more research.
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 09-06-2007, 12:14 AM   #3
supradaddy0803
supradaddy0803's Avatar
Do a search here on the wireing harness tuck saves so much time and headach with extending the harness.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 09-06-2007, 04:33 AM   #4
oowee623
oowee623's Avatar
hey supradaddy, how long have you known about that i only heard it from you and then again from driftmotion on saturday, is this a relatively new method or has it been around for awhile?
Old 09-06-2007, 03:21 PM   #5
stanley2001
Default Thanks oowee623 Bell housing?
Thanks oowee623. If I get the 1jz with tranny (Auto), do I still have to do something about the bellhousing? I guess the drive shaft is still no problem, no? Thanks, I still am doing my homework.
Stan '91 turbo
Old 09-06-2007, 03:47 PM   #6
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Method has been around for awhile. I remember hearing about it about 2 1?2 years ago from one of my buddies going through the same thing :-)
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 09-07-2007, 12:25 AM   #7
oowee623
oowee623's Avatar
if it comes with the tranny then it will come with the right bellhousing since im assuming its already attached to the engine, and with the driveshaft it depends on it its auto, turbo 5 speed, or na 5 speed, they all have different splines. you'll only need the front peice of the driveshaft though, the back peice is tha same regardless of the tranny
